The test was run on the Dallara F308:
The fenders are substantially more complex than on the 312 shown before. They appear to do quite an important job guiding air into the coke bottle and around the rear wheel. The 312 is much simpler as a whole around this area - the sidepods and coke bottle are much more like post-2009 F1. On the whole this means that the 312's fenders themselves are less complex because they have to direct and manage fewer flow streams.
On the issue of increasing front downforce:
Looking precisely at the bottom of the fender and where it attaches to the floor, it is angled straight outwards, thus acting as a splitter, or a front diffuser. It blocks the air going over the top of the floor, increasing the pressure differential at this point. This will enhance the downforce created at the leading edge of the floor, and...
hollus wrote:
...flow over the front wing will have to eventually find a path around that stagnant flow (which might well exist only in my imagination), and probably starts to do so while interacting with the front wing.
is also a good theory.
But that depends on exactly where the fenders were removed. If the front corner of the floor was removed, it would fairly obviously decrease the front downforce, and I don't have the information to know that. Still, having the fenders IS shown by the data to be beneficial.
In F1, the fender is one of very few parts that is virtually de-regulated, and is therefore a good indication of what teams are trying to do. Ferrari notably have been very active in this area:
I would suggest in Ferrari's case their 'Acer duct' combined with the quite wide sidepods (very little undercut by the 'infor' logo) is choking the coke bottle and causing it to not work as effectively as it has in the past. This is what is creating the stagnant flow problem under the sidepod. They have played around with the turning vanes, floor leading edge, front wing and pylons to improve it, but on the whole it is an issue that has arisen from the car's agressive design, and it will be difficult to properly solve.
"A wise man speaks because he has something to say; a fool speaks because he has to say something."
