I wonder what happens inside the engine if it gets broken.
Which parts do exactly cause the engine to blow up in a big
cloud of fog?
I don't think that you will loose the hole engine,
if a piston ring breaks.
Good explanaition.The traction control is done by cutting the spark to the engines, so when it is activated, it's not a smooth process.
Most likely a bearing tightened up, led to increased torsional load on a rod, it broke, went crazy inside the block and tore up the piston, valves, head, block, and everything else.
"As mentioned earlier there are various ways to implement traction control. In Formula One, wheelspin is reduced by cutting the engine power. While each engine has its own system, the power output is either reduced by cutting fuel supply or by retarding or suppressing the spark. Obviously, cutting the fuel to one or more cylinders is beneficial for fuel economy. Current F1 systems use a combination of these factors to ensure optimum performance. A traction control system can be heard in operation very clearly when cars launch out of slow corners. The engine produces a rough sound, caused by the misfires (a cylinder's fuel that doesn't get fired)."manchild wrote:I think that's how first TC system worked. Modern systems don't cut ignition but reduce fuel injection. At least Renault has such system for years now. Perhaps Ferrari's system still cuts ingnition.
It is the first assumption Peroa, because of the lower tire adhesion. Because the drivetrain cannot deliver maximum torque to the driveshaft, then lower values imply longer component life. But since a Formula One car delivers so much power, some form of traction control is used by all. And that is where the killer of engines lives. It cuts out the power, and rather abruptly. If you ever listen closely to traction controlling working, instead of the smooth and consistent firing noises coming out of the exhaust pipe, you hear distinct bangs and pops. And each one delivers a shock to the drivetrain. The idea towards longer component life is to have a smooth, consistent delivery of torque through the drivetrain. That way, the gears and parts don't get large, abrupt shocks, but a lot of lesser shocks.peroa wrote:Well, Alonso said they have a 120% engine available as they only used it for 80% in China.
So either the Renault has a different system or your explanation is a bit off because every time I hear something about engines in the wet everybody says that it is not so stressful in wet conditions.
Well Dave, I honoustly can't see how reduction of fuel input into a cylinder can actually increase the load on a piston or connection rod. It looks to me that it's even the opposite as less ignited fuel is less expansion pressure just after the ignition.DaveKillens wrote:It could be manchild, I don't know the exact method. But regardless of what system is applied, cutting spark or fuel in this manner places tremendous, brutal loads on the drivetrain. It shortens the life of any engine.
