Panoz ALMS P1 engine - carbon fiber block?
countersteer
Article by Marshall Pruett detailing the return of the Deltawing and, more important to this post, the development of a new twin turbo race engine and a rumored carbon fiber block.
(I thought it best to post this separate from the Deltawing thread that already exists as I am more interested in the engine development at this point. Apologies to the moderators if they disagree and would like to merge threads.)
http://auto-racing.speedtv.com/article/ ... chassis/P1
Based off of the 2.0-liter Mazda MZR engine found in the Van Diemen Elan USF2000 chassis, the new mill is slightly smaller at 1.9 liters, and adds both direct fuel-injection and a twin turbo system to double the 4-cylinder, twin-cam’s output.
Rated at 170hp in the USF2000 car, the DeltaWing unit, which replaces the 1.6-liter RML-designed Nissan engine that propelled the car in 2012, is currently achieving 345hp on the dyno, with 350 lf-ft. of torque at 6500rpms.
“We’re about 15 pounds lighter than the Nissan engine right now and two inches shorter than the stock Mazda,” Panoz continued. “This engine is being developed for P1 and P2; we’re doing a batch of 40 engines at the moment. We liked what we saw with the bottom end of the one Mazda engine, and the top end of another Mazda engine, so we’re putting them together with the new billet block.”
“It can make more power and we’re committed to making them a success,” he said. “They can be branded other things if a manufacturer wants to talk with us about that. And we have another version of this engine we’re working on, a second type you could say, that’s the ‘real’ P1 engine and has an innovative block with a new material we’re trying that’s 20 pounds lighter.”
That material, according to my sources, is carbon fiber. - Marshall Pruett
Lycoming
106
Re: Panoz ALMS P1 engine - carbon fiber block?
I seriously doubt they could have made the entire block out of carbon fiber. Perhaps some bits and pieces here and there, casings, etc. but not a whole block.
I wouldn't read into it too much.
The block and a lot of structures could very well be carbon fibre, but I dont think it is used inside cylinders for example.
riff_raff
132
The notion of a carbon fiber composite engine block is a bit silly. While it may sound great in theory, in practice it would not provide any worthwhile benefit. A carbon fiber composite block would make for a stiff and lightweight structure in a chassis using a stressed engine. However, once all of the metal interfaces are added to the composite block, like those needed for mechanical interfaces with the heads, cylinder liners, main bearing saddles, coolant jackets, etc., the weight savings is minimal.
A: Start with a large one!"
FW17
168
What about Torlon thermoplastic? I remember 80's engine called POLIMOTOR which was a 1/3rd the weight for a metal engine.
hpras
Wow, what struck me reading the article is that Panoz has severed almost every connection to the prior car that he had and is going it alone. Nissan, gone. Gurney, gone. Hicroft, gone. Bowlby, gone. Michelin, maybe gone. The only connection to the old car seems to be the AMR-One chassis that the original was based on. I'm having to guess someone must have signed over some serious IP to get Panoz's backing.
strad
117
Sir Stirling Moss
620
Magnesium alloys are much lighter than Aluminium alloys, but have only slightly higher thermal expansion coefficient
a material with a much higher expansion coefficient would be a problem to the engineer ?
countersteer
Not to be argumentative... but.... Didn't we say the same thing about a carbon fiber gearbox back in the day? And, after many failed attempts, carbon fiber cased gearboxes are in use up and down the grid?
aussiegman
105
A carbon fibre engine block should be achievable with the correct coatings, impregnated fixings for head and crank as well as metal cylinder liners. Possibly plasma spray coated liners.
Why not??
strad
117
Composite Castings LLC (CC) announces the launch of its new, lightweight, carbon fiber composite, 4-cylinder engine blocks. This novel engine block design was developed by Matti Holtzberg, President and founder of Composite Castings, based in West Palm Beach, Florida, USA. Extensive research resulted in the selection of Toho Tenax America’s Tenax® brand carbon fiber as the reinforcement for the base epoxy resin.
The resulting high performance compound is molded into the finished engine block profile using CC.s proprietary molding process (patented and patent pending) that uses low cost tooling and provides for faster cycle times compared to conventional CFRP molding methods.
http://www.thecarbonfiberjournal.com/?p=770
Sir Stirling Moss
