R_Redding wrote:In Forzas first photo above (
http://octanephotos.co.uk/gallery/cache ... 7d8520.jpg)
It looks like the exhaust flow is not sticking to its "coanda" channel ,but rather exiting at the side as can be seen from the scorch marks.
I wonder if the narrower sidepods are giving enough "over the top" downwash to help the effect , or wether the sidepods are producing turbulance in that area by not having as pronounced coke bottle shape as some of the other cars.
Rob
I agree that the exhaust gases doesn't seem to be going perfectly where Sauber would want to, as the scorch marks suggests.
However, this doesn't look to be related to downwash over it. The plume is going down, it just seems to be, laterally, not going in the desired path. The plume should go straight to seal the diffuser gaps, with the tire, and not go laterally towards the center of the car.
About the turbulence, this is exactly what Sauber design should mostly avoid unlike the kinds of Ferrari, for instance.
Turbulence in airflow occurs when the viscosity(the shear forces, which acts tangentially to it, between layers of airflow) is no longer enough to hold the airflow layers together, so separations happens.
Coanda effect is the name given to the behaviour of a fluid flow to follow, as it's path, the shape of a body's surface nearby.
If the shape of the body is not smooth, ie, if it requires the flow to have a big change in it's direction, then the force necessary to do so will exceed the force holding the fluid layers together and the separation occurs. The boundary layer will remain attached to the body's surface as this region have much less velocity(nearly 0) than the remaing part of the flow, but it will separates from the adjacent layers.
Ferraris sidepods and cokebottle require the flow to make a big change in direction while Sauber's doesn't. Ferrari have, or had, many problems with correlating it's wind tunnel data to the actual aerodynamic result on "open field"
Due to Reynold's numbers issues, you can easily have correlation problems between wind tunnel data and actual race enviroment result.
My modest guess is that the simulating tools, which Ferrari is using, are giving them some wrong perceptions in that area(calibration needed, eventhough now Ferrari is using Toyota's wind tunnel which have a very good reputation). I wouldn't be surprised at all if that big empty space(underneath the exhaust pipe exit) is having some turbulence in it. If the sidepod was tighter(especially like the C32's), it could be a marvelous packaging.....
Anyway, it's all guess work now. After Melbourne/Sepang/China we, maybe, can have a clearer picture of which design might be the best.
Sauber was saying on twitter that it was working on aerodynamic evaluation and setup work the entire 2 days. They are not even looking for laptimes, which I like. Better to have innovative aero to test with at this stage, than be already this early kind of "ready" and looking for laptimes and long stint tests as some other teams seems to be doing(Mercedes, for instance)
Additionally, so far, trackside observers, as well as Hulkenberg himself, were reporting that the Sauber car maintain it's characteristics of high downforce. That, together with the inherent low drag that the car might have, makes me quite positive about C32 untill now.
If not in the remaing 2 days of this week's test, I'm sure Sauber will show what it is capable in the final Barcelona test, next month.
