2013 Australian GP - Albert Park
240
Re: 2013 Australian GP - Albert Park
Neno wrote: its not possible to change rear wing in two minutes, unless it's constructed and complete seperate from gearbox on who is going beam wing and rear wing. Rear wing is not front wing. Also his rear wing was not damaged that way that rear wing broke completly, it looked after kick in wall as one plate of rear wing was just loosen off and started going left-right.
They changed hamilton's rear wing in Monaco in about 5 minutes before if i remember correctly. And that was a very technical pull down and refitting, which was done on the grid. Mechanics had to be going back and forth.
2 minutes is reasonable, depending on the damage.
hollus
With all the work that goes into conditioning the track for the race... wouldn't it be possible to simply remove all the painted lines that should not be there and paint them again after the weekend?
TANSTAAFL
dren
227
Looks like sun for tomorrow.
Honda!
raymondu999
It was basically a snapped endplate - another car basically mounted Lewis's car from the rear, and the endplate broke. They basically replaced one endplate, but Lewis couldn't deploy DRS for the rest of the race
失败者找理由,成功者找方法
bhall
bhall
244
Don't you mean he basically couldn't deploy DRS for the rest of the race? :wink:
As I had posted earlier, it will be mostly sunny with some hazy clouds but it will be cold and windy, and the end of the race is going to be murder on the tires because by then the track will start cooling off as well
Redragon
19
I have to say, a bit out of topic, the live chat during qualifying was great. It gave me a sense of your real characters,
leaving a side those little egos on technological knowledge and bringing proper fun to what it was in my case a bit desappointing early morning. I would not be able to be on by the qualifying time but would try to be during the race.
As I said real fun, looking for to chat with you soon
Shrieker
Hamilton's right rear tyre took a hefty impact. Can they claim damage and change the suspension/wishbone before q2 ? I would definitely have it changed if I was the team boss.
-Atatürk
Mika1
Mika1
Shrieker wrote:Hamilton's right rear tyre took a hefty impact. Can they claim damage and change the suspension/wishbone before q2 ? I would definitely have it changed if I was the team boss.
No worries, only the rear wing was damaged.
The boss follows me on twitter.
bdr529
59
hollus wrote:With all the work that goes into conditioning the track for the race... wouldn't it be possible to simply remove all the painted lines that should not be there and paint them again after the weekend?
There's only a few ways you can remove the lines, high pressure water or grind them off. either way not cheep or quick
CjC
CjC
I've seen it done with a blow torch and it is extremely slow
Just a fan's point of view
simieski
simieski
http://www.roadlineremoval.com.au/
The video on this link appears to show it as a relatively quick process. But then I guess it is also the the cost of doing this, combined with the cost of re-applying the lines weighed against how often it does rain. Besides, is it such a bad thing the drivers having to be careful of them?
Thank you to God for making me an Atheist - Ricky Gervais.
Redragon
19
Interesting reading of Road Surface Marking
http://en.wikipedia.org/wiki/Road_surface_marking
I guess it is not so simple to remove them
raymondu999
bhallg2k wrote:Don't you mean he basically couldn't deploy DRS for the rest of the race? :wink:
Was that not what I said? There was some structuraldamage to the point that the team were worried the assembly would disintegrate if he were to turn DRS on.
失败者找理由,成功者找方法
Lycoming
Lycoming
106
Really? when I first read that I thought it was because the hydraulics were damaged. Why would that be the case? DRS reduces loads on the structure.
simieski wrote:. Besides, is it such a bad thing the drivers having to be careful of them?
No, but they're everywhere, to the point where they're nearly unavoidable, turn 1 being an example.
