2013 Chinese GP - Shanghai
raymondu999
Re: 2013 Chinese GP - Shanghai
iotar__ wrote:There's also nothing behind "tyres limiting speed" claim. 1. We've got only those tyres. 2. Cars can't run without tyres. 3. Speed of the car = speed with tyres. There's no theoretical speed of the car without tyres and thus tyres limiting speed. Claims that "they could go faster if not for the tyres" (not yours to be clear) make little sense because they are based on mixing theoretical values with real life data and results.
I'm quite sure what he means is that, if there was an option (as video games have) to set tyre wear to 0, then the Red Bull would be lapping the driver in P3 every race.
失败者找理由,成功者找方法
f1316
89
raymondu99 wrote:
iotar__ wrote:There's also nothing behind "tyres limiting speed" claim. 1. We've got only those tyres. 2. Cars can't run without tyres. 3. Speed of the car = speed with tyres. There's no theoretical speed of the car without tyres and thus tyres limiting speed. Claims that "they could go faster if not for the tyres" (not yours to be clear) makadvantage little sense because they are based on mixing theoretical values with real life data and results.
And you believe they have that kind of advantage? I for one most certainly do not.
raymondu999
Believe or not is irrelevant - because this isn't a video game where you can dial down tyre wear to 0.
失败者找理由,成功者找方法
hollus
Exactly. If I could set inertia and drag to 0, I would be lapping the entire field, Bulls included, in my bicycle. But I cannot, as they cannot set tire wear to 0.
¡Puxa Sporting!
240
Well if you get a race like /india 2012, you will see more dominance because the tyres dont wear much there.
raymondu999
ringo wrote:Well if you get a race like /india 2012, you will see more dominance because the tyres dont wear much there.
Agreed - just about. With the caveat that of course it remains to be seen what the tyre choices will be for India, Abu Dhabi etc this year, and whether or not they will display similar characteristics to last year in hardly wearing. Maybe Pirelli might even bring along soft and supersofts for Austin, Abu Dhabi etc.
失败者找理由,成功者找方法
ajdavison2
ajdavison2
30
Yes but was that becuase of the tracks having low-wear characteristics, or because the teams had got a handle on the tyres by that point?
raymondu999
If James Allison is anything to go by, in the latest JA on F1 podcast he says that it was an overused term - the one-stop races were primarily because the tyres were generally too durable for the respective track surfaces.
失败者找理由,成功者找方法
iotar__ wrote:
n smikle wrote: The car is about half a second ahead of the other cars but the tyres have limited the RB's pace in the races we have had so far. You actually might see the true pace of the RB on the more milder down-force dependent tracks.
0,5 s ahead? What do you mean by that? The only thing we've got is: current tracks, current races and current results. So in which parallel universe is RB faster by 0,5 s? Over one lap? Average over the whole race distance? That would be overall 28 s.
I mean flat out with fresh tyres.
There is something behind saying the tyres limit the speed of the cars. Give me Michelins and You take the Pirellis and lets race over a distance and see who finishes first. Well, lets see who finishes! coz I know you wont even make it past 20 laps! If you see what I mean. So when I say tyres limit the pace, I litterally mean the pace of the car over the race is heavily dictated by the wear of the tyres. Even if your car is half a second quicker than mine on fresh tyres, there will be a point in the race when both of us have to travel at near identical pace to save them.
And what do you mean by true pace? The one after they have figured out tyre degradation? [Leaving tracks aside which is another variable. After Melbourne it was only about tyres, now it's about tyres AND tracks. Interesting correlation between results and reasons behind them.] Well, it's going to be a different car then. Developed based on data from actual races, on actual tyres. Not theoretical ones.
By True pace, I mean the results in lap time on fresh tyres in the race. Say you could go flat out from start to finish like the 2012 USA GP.
theblackangus
theblackangus
This may or may not be true. If both teams were given a year to design tires to the same spec I would bet the results were very close.
If you chose to compare apples (previous Michelin) to oranges (current Pirellis) then that is simply not useful, as they were designed to different specs.
Nando
Nando
You guys are talking about two different things.
Best car and fastest car. They are not the same.
SilverArrow10
I know its a long way off but i'm bord without F1 around so i'm going to have a go at who will be on the podium in china or rather what I want to happen.
1st - Hamilton
2nd- Alonso
3rd- Rosberg
(biased I know)
Mind you for this to happen both Red bulls will have to mess up and to keep the championship alive I hope that happens, not likely though. Expect an improved McLaren as well possible top 5.
flynfrog
n smikle wrote:snip
Or you could go with a current spec v8 and I will run a one race v10, 2006 spec areo packages vs 2009. Fuel stops vs no fuel stops. Different rules different cars different paces and strategies. Trying to argue one way or another is rather pointless as the different rule sets dictate a different maximum.
Hail22
144
Formula 1 is arriving extremely early...these photos were recently taken from the Pudong International Airport in Shanghai China:
Gilles Villeneuve
Gridlock
42
Are you sure they're this year? There's an SL but no SLS so probably 2010 or so?
#58
