I think in your view everything is too restrictive unless it allowed your ESERU design.autogyro wrote:I suggested a combination of battery and capacitor storage some years ago, so I doubt Adrian using the idea is a rumour. In 2014 the technology will be held back even more by the regulations.
I think there's something wrong in your claims. How can one discharge more energy than is stored?fast_ian wrote: - Maximum allowable energy store is currently 300KJ (with a max discharge of 400KJ / lap). 2014 sees this increase to 4MJ / lap
Ian
You're forgetting you can charge as well as discharge in the same lap...... I re-read the rules as it struck me as strange on initial read.....Dragonfly wrote:I think there's something wrong in your claims. How can one discharge more energy than is stored?fast_ian wrote: - Maximum allowable energy store is currently 300KJ (with a max discharge of 400KJ / lap). 2014 sees this increase to 4MJ / lap
Ian
And also besides the fixed amount there is a fixed max. discharge rate in the rules.
fast_ian wrote: You're forgetting you can charge as well as discharge in the same lap...... I re-read the rules as it struck me as strange on initial read.....
I'd need to check again, but don't think there's any max discharge rate, at least this year.
Cheers,
Ian
I think the bolded part is where you got confused. This is the total amount of stored energy WITHOUT the KERS storage. The latter capacity is actually not defined explicitly since the discharge rate and amount used per lap are enough. Because a larger than needed capacity is only a weight penalty. They say that RBR even have less capacity than the rest in the pursuit of less weight.5.2.2
With the exception of one fully charged KERS, the total amount of recoverable energy stored
on the car must not exceed 300kJ. Any which
may be recovered at a rate greater than 2kW
must not exceed 20kJ.
I think it's measured on the electric bus, but the rules talk about mechanical power when considering the efficiency of the conversion is @95%. So they can use 60kW/0.95 electrical power peak. I haven't figured out if the energy limit is in electric or mechanical joules, there is a small but measurable delta between them.Tommy Cookers wrote:the max discharge rate is equivalent to the motor power limits (60 kW now, 120 kW in 2014)
I presume these are output values ie mechanical power
does anyone know ?
My bad! You're absolutely correct. I stand corrected.Dragonfly wrote:I think the bolded part is where you got confused. This is the total amount of stored energy WITHOUT the KERS storage. The latter capacity is actually not defined explicitly since the discharge rate and amount used per lap are enough. Because a larger than needed capacity is only a weight penalty. They say that RBR even have less capacity than the rest in the pursuit of less weight.
I am afraid this is not the case with current KERS.fast_ian wrote:[
My bad! You're absolutely correct. I stand corrected.![]()
However, my point about using more in one lap than can be stored still stands..... We see 'em do that quite a bit in fact - Start the lap "full", use (some of) it, recharge and fire it again.
Cheers,
Ian
The gauge on the screen really has nothing to do with how much energy there is in the battery. It's only related to the amount "allowed" by the control ECU to be fed to the KERS. The battery may be full, empty or anything in between when you cross the S/F line. It's a shame that the commentators associate the gauge on the screen with the energy stored in the battery; it's probably easier to explain, but wrong nonetheless. For example, suppose a driver uses up it's full battery while accelerating on the S/F line, when he passes the line the gauge will show full although the battery can be empty; the driver brakes at the end of the line for turn 1 and fills up the battery with the Kers as generator - the gauge on the TV screen won't go up, but the battery does charge.Dragonfly wrote: I am afraid this is not the case with current KERS.
The gauge you see on the TV screen resets to full only once in a lap when the car crosses the S/F line. And it only means that the ECU will allow a new portion of the allowed amount of energy to be used for that lap - either in a single shot at the max allowed rate, or in smaller portions. But that's all.
In reality the batteries probably have a bit larger capacity and recharge every time the system harvests energy under braking and is almost always charged. But the electronics in the car are programmed to the current usage rules.
It will be entirely another matter in 2014 when not only more energy can be stored and used but energy from the MGU-H can be directly fed and used by the MGU-K, coupled to the engine.
