Cut Tyres
beelsebob
beelsebob
85
Cut Tyres
So, Pirelli have repeatedly claimed that the tyre failures are due to cut tyres. Given that Vettel's engineers are saying that his tyre was indeed covered in cuts after his first pit stop, that seems to be true...
But...
The tyres were not being cut up all the time last year, nor the year before etc. And the curbs and g-forces etc all existed in past years. To me, this clearly indicates that there's an issue with the design of the current tyres which makes it very easily cut, or even which makes cuts naturally develop in it under certain kinds of stress.
This race has changed my opinion from "it's just punctures, which have occurred long before the blow up occurs", to "it is punctures... but those punctures are being caused by some design flaw in the tyre".
Holm86
261
Re: Cut Tyres
Porsche super cup ran on Silverstone before the F1 GP. They run the curbs just as hard. And they didn't have troubles with cut tires.
Has to be a problem with the Pirelli's.
gavingav1
35
Re: Cut Tyres
ever tighter bodywork and exhaust blowing cant be helping,if the Tyre is deforming under load, could be touching some part of the cars floor or those little wings attached to the rear brakes
Goran2812
Goran2812
27
Re: Cut Tyres
gavingav1 wrote:ever tighter bodywork and exhaust blowing cant be helping,if the Tyre is deforming under load, could be touching some part of the cars floor or those little wings attached to the rear brakes
no way... the new sidewall has to be the problem. making the tire flex differently and making it's edges more exposed to stress and forces while riding curbs...
Visit my photo page! -> http://www.gorankphoto.com/formula1
beelsebob
beelsebob
85
Re: Cut Tyres
What, all the teams suddenly made the exact same development that started cutting the tyres all in one year?
That doesn't sound likely as an answer to me.
Re: Cut Tyres
Gary Anderson just showed the kerb on T4 and how sharp it is. Looks like if you got the tyre in just the wrong place on the apex then you were at risk of a cut tyre.
A sharp kerb isn't Pirelli's fault...
beelsebob
beelsebob
85
Re: Cut Tyres
Just_a_fan wrote:Gary Anderson just showed the kerb on T4 and how sharp it is. Looks like if you got the tyre in just the wrong place on the apex then you were at risk of a cut tyre.
As I said on the race thread – that kerb's been there for years, it's also not been cutting other formula's tyres. It's not an issue with the kerb.
Tim.Wright
330
Re: Cut Tyres
Tracks have curbs
The tyres need to be able to drive over curbs
Like they have been doing for the past 60+ years in F1
bhall
bhall
244
Re: Cut Tyres
beelsebob wrote:What, all the teams suddenly made the exact same development that started cutting the tyres all in one year?
No, but the tires this year have more flexible sidewalls, and an unloaded tire, such as the left-rear in left-hand corner for instance, could deform to such a degree that it comes into contact with the floor of the car. The tolerances in that area are very small.
It's not an implausible scenario.
gavingav1
35
Re: Cut Tyres
Nice picture to illustrate my point -car designers are pushing the limits to far ,running tyres under pressure and the tyres are deforming too much ,thats why after the punctures at silverstone they upped the tire pressures and continued to ride the kerbs without problems
beelsebob
beelsebob
85
Re: Cut Tyres
gavingav1 wrote:Nice picture to illustrate my point -car designers are pushing the limits to far ,running tyres under pressure and the tyres are deforming too much ,thats why after the punctures at silverstone they upped the tire pressures and continued to ride the kerbs without problems
Right, Perez didn't have a problem with 12 laps to go. Wait...
Re: Cut Tyres
If the floor was cutting the tyre, then we would have it much more often, and we would certainly have seen certain teams remarkably not having any problems with it. Furthermore, if that was the case we would have had Pirelli inmediately pointing at it. I see no indication whatsoever that the floor is cutting the tyre. Teams would have noticed that very early in the pre season, left alone at the start of the season.
That specific curb is obviously the point where it is most likely to happen: high speed corner, sharper edge,... . The tyres would get the biggest loads to deal with there. However, that still does not mean the curb is the cause. Cars have been driving over there very agressively since years. I can't remember a single case that that curb initiated a deflation of a tyre. This is more due to Pirelli who designed too weak tyres. They are probably very right to point out the delamination are caused in most cases by a cut in the tyre, but they very conviently forget the important question: was the situation bad enough to justify a cut?
Jonnycraig
Jonnycraig
Re: Cut Tyres
Ferrari, Red Bull, McLaren, Mercedes & Toro Rosso just don't understand the tyres.. :roll:
ScottB
ScottB
Re: Cut Tyres
It does seem likely that it was the kerb at turn 4 causing the issue, however as others have rightly pointed out, unless this kerb is brand new this year, it hasn't happened before. So whether it is a mixture of the teams pushing things too far, a problem with the tyres or all of it, something needs to be done.
Hopefully a balance can be struck between a tyre that degrades too much too soon, and the boring, never degrading Bridgestones.
myurr
myurr
Re: Cut Tyres
Massa's tyre also deflated before he reached that kerb. I'd be surprised if he cut it there on the previous lap and then it failed at the exact same point a lap later.
