VectorOne wrote:Ah ok, First check that your car meets every single regulation, The worst thing you can do is lose points because your car isnt to specs. Ive noticed that your front airfoil may be too thin, I would check that regulation. Also have you run any wind tunnel tests on your car? What was your drag coeffeicent? What kind of bearings are you using in your car? Your front airfoil lets too much air through, you want to try and deflect that around/or above the wheels.... If you can post a picture of your car running a wind tunnel simulation, that would help us find spots for improvement.... Also Good Luck at regionals!
-Daniel
VectorOne Canada
Thanks
okay i've made several changes. i've tested the car in the Project Falcon VWT and the drag is 1.30N.
Im using Full Ceramic bearings which my seniors suggested me.and why do you think letting too much air below the wheels is not a good idea ?
