Constructed for Brough Superior in the Los Angeles . British design but built in the U.S by workshops of TaylorMade Racing. The new bike has been jointly developed for Brough by Taylor and UK-based designer John Keogh, who worked with Buell on creating the Firebolt and other models.
Name, mark: Taylormade Carbon2 Btw. who is Taylormade Racing? Taylormade racing based in Van Nuys, Los Angeles, California, USA, is a specialist in innovative design and manufacture of carbon-fibre components, to Formula One standards. It is a discreet supplier to the Yamaha, Honda and Buell race teams as well as producing its own range of hi-tech exhaust mufflers for street bikes, which have attracted much attention for their light weight and integrated design.
Tech goods:
- -Obvious Moto2 spec engine: Honda CBR 600, 4 cyl
- -unique carbon fiber composite chassis that integrates the fuel tank and bodywork in a single monocoque fabrication – "fuel inside chassis" => thus cutting weight while increasing overall stiffness.
- -rear carbon fiber swingarm + Penske shocks
- -high front 43mm in diameter fork tubes=>more space => less obstructions for cooling air
- -CofG placed vertical narrow fuel tank (almost behind engine) => lover "splashing" and fuel drop efects=> better race pace
- -rear tail-sectioned radiators look picture below (KLIK for enlarge pictures
Nice CFD pic, Nice view into low pressure zones behind exit of the rads and also steady flow around sides of windshields...
Look Moto3 bike..?! Oh no! Damm it so narrow..
Really nice neat design. Maybe nowadys are manufactures a little to much conservative and they stick "old" ways how to construct proper ride friendly bike. I m looking foward to it and let see how it goes on the test track...Paul Taylor wrote:As chassis designers, this was a very exciting prospect (Moto2)...
...with the Brough Superior Moto2 we hope to prove to teams that thinking outside the box, combined with rigorous testing
and development, can deliver a competitive advantage.
Test rider Former AMA racer and factory Buell racer Shawn Higbee has been developing the bike on track, and says:
It a shame it doesnt have Akrapovič exhaust systems..It's very narrow, so that's one advantage,” “And also very light and agile. But the thing that stands out most is the
way it absorbs bumps even when you're trail-braking very late and very hard into a turn, because the front end has such little stiction when the bike is leaned over. With a conventional telescopic fork, when you get a full lean and the forks get twisted and bound with lateral forces, they don't work as good as they normally should – but on this bike the front keeps right on working well. It gives you an awful lot of confidence to attack the corners at full lean even with the brakes hard on. It has so much potential once you get your head around the different things it'll do that a conventional bike will not.
ALERT!!!Its NOT Brough Superior picture!!! I just added for comparison how different looks conventional Moto2 bike around frames, engine and its ancillary. There is no doubt how immense reconstruction must take place on this bike. Even if we think how effective you must work to achieve proper compromise between required empty space for tunnel and reservoir tanks etc. this is completely different philosophy. Interestingly how they played with mass redistributions. Putting some weight foward (engine) and bacwards (rads). Like those changes was not big enough, then made step further and even loose some of it (carbon fiber). Nice gambling design! Of course it is nothing new on the "race" or conventional marked, but they combine all ideas in 1 BIG "revolutionry" beast!!! =D>
NICE FOCUS PIC: really nice reading...
Sources: LINK 1, LINK 2, Magazine Cycle News Vol 50 issue 34
