Traction wrote:Probably the most intelligent post in this entire thread...it's a pity the logic and explanation given in the link will largely be ignored or brushed aside. People will rather focus on trying to discredit RB without looking at the facts. =D> +1
Hold on a minute, who is trying to discredit Red Bull?
If they have found a method to get traction control that is not controlled within the rules, then that is not to discredit them. It's Formula One, not a charity after all. This happens when any team comes up with innovative ideas.
People will always get upset, but should in fact applaud Red Bull for their masterful innovation.
We also know Red Bull to be master's of concealment, and master's of rule interpretation.
Instead of looking at this as people discrediting a team, maybe it is better to view at as a thread for people to a)ascertain whether there is anything going on
b)how it is done
c)whether it is legal should a) and b) be conclusive.
In the James Allen piece you have just put it up it does say this:
While there does seem to be some work being undertaken in engine mapping to work around the ban on exhaust blowing, which may have contributed to the strange sound, the issue of traction control is broadly taken care of by the common Electronic Control Unit, which is manufactured for the FIA by McLaren Electronics. Because the unit is specified and the same for every team, it is hard to conceal a traction control command in what is essentially a spec part. Rather than traction control, some kind of mapping to blow into the exhaust within the rules is more likely and this all fits with the corner exit work that Red Bull has been carrying out.
However, the problem I have with this assessment is that the ECU may be spec, but it is programmable.
It's like having 10 identical laptops with different programme requirements.
For example, you cannot have the Red Bull programmed ECU in the Mercedes powered McLaren. Each ECU will be tailored to each driver and team.
In addition there is alot of guess work from Mark Gillian.
We have this:
The key to this is that Red Bull has done a lot of work on traction out of low speed corners
Which can imply many things including that which we are discussing in this very thread.
However, this next line is very general and cannot be pointed to any real tangible outside improvement.
Red Bull chassis have always had very high amounts of downforce, but here they’ve worked to ensure that it isn’t just about high load, it’s about the stability of the load, which is a big focus. Red Bull has always been able to push the diffuser hard in the high speed corners, the key to their speed now is that they have tuned it to work at low speed.
Nothing can physically be pointed out here. The diffuser works better, apparently. Why does it work better?
Because Red Bull worked hard on it? That's the reason given...
Also pointed out was there thermal management work, yet Mercedes and others have also done similar work.
r
Right down to the heat dissipating rims.
Finally, there is another grey area.
It may be hard to conceal...but is impossible?
We just don't know yet. I wouldn't be quick to dismiss it, but we know Red Bull ran some pretty aggressive maps, which led to spark plugs capitulating...recall that?
This in 2010...so they have a very good and long working knowledge of it.
I'm not saying it isn't true. But we have nothing concrete from Gillian. It is as speculative as any on this thread.
If he brought something tangible to the table, this story would be dispelled in a heart beat.
Let's focus on the positives.
