2014 Design
FW17
184
Re: 2014 Design
Tim.Wright wrote:You dont need a lot of section area to get by in the crash tests:
http://thejudge13.files.wordpress.com/2 ... fwnose.jpg
It is a lot easier structurally to have the nose cone as straight as possible from the front of the chassis, design is simple and slender sections are possible. However in case of next year the tip of the nose cone is at 185 mm, the upper part of the chassis is at 525 mm, the lower is at 250 mm this drooping shape along with a slender section is a more difficult / heavier design compared to current nose cones.
Re: 2014 Design
What do you think of this idea, the old Williams FW26 adapted to Regulation 2014?
http://www.newsf1.it
djos
130
Re: 2014 Design
Completely non-compliant.
"In downforce we trust"
Huntresa
Huntresa
Re: 2014 Design
djos wrote:Completely non-compliant.
Why ? From what i can see it doesnt break any rules, assuming you make the pylons and nose etc within the regulations.
djos
130
Re: 2014 Design
It's already been discussed several times in this topic.
SectorOne
Re: 2014 Design
I don´t think you have looked at the picture more closely.
FW17
184
Re: 2014 Design
If the engine radiator is going to be only on one side, does that mean it will be 33% larger inlet and surface area (as a minimum) will be required?
Re: 2014 Design
The Radiator shown on this Picture is the Turbo Intercooler.
Plus this is just an eraly mock up Picture, ecth Team will come up with different Radiator Placements and Sizes.
Blanchimont
Blanchimont
214
Re: 2014 Design
The presentation video of the 2014 Ferrari engine ( http://www.youtube.com/watch?v=qLcbF2uI05s ) shows more of the possible radiator/intercooler layout. The MGUK and the ERS battery each has a seperate one, i would guess that the MGUH will also demand cooling, so the picture seems not to be complete.
Dear FIA, if you read this, please pm me for a redesign of the Technical Regulations to avoid finger nose shapes for 2016! :-)
Re: 2014 Design
Do the MGUs really need separate radaitors ? maybe... but AFAIR, the MGUK between 2009 and 2013 used the same oil as the engine...
Allison said the new Ferrari has 6 radiators, AFAIR; it could be:
1 rad for the Gear-box
2 rads for the engine
1 rad for the ES
1 intercooler
1 for the MGUH and MGUK ?
WhiteBlue
92
Re: 2014 Design
The electric components of the ERS will all need fluid cooling. Those components are:
1. MGU-H
2. MGU-K
3. Storage pack
4. Power electronics (inverter)
Other cooling needs of the power train are:
5. Engine
6. Gearbox
7. Intercooler
8. Turbo bearing assembly
I reckon you can put 1 & 2 and 3 & 4 on common parallel circulation with one heat exchanger. The MGUs will tolerate higher temperatures than the electronics and it sounds feasible to put them on the engine oil circulation before the oil hits the engine or the turbo charger assembly. But I freely admit that I do not know the specific considerations.
But one thing is for sure. Heat management is obviously worrying many teams and can be expected to cause a few surprises for those teams who have lesser resources and design capacity to spend on exploiting alternative designs.
idfx
53
Re: 2014 Design
this is the video presentation of the renault.
These videos (in Cg) are just ideas and not the final design. :wink:
[youtube]http://www.youtube.com/watch?v=0UKtPWfecqE[/youtube]
the EDGE
the EDGE
68
Re: 2014 Design
I think I herd on the racers edge with Peter Windsor that the intercooler would require a side pod all to its self and all other Cooling would be housed in the other. The engines will require way less cooling than before because of the reduction in size but obviously the increased electronic recovery systems will require way more
its episode 22, interviews with Craig Scarborough, Tim goss from McLaren and a guy from Mobile 1, well worth a watch if you haven't seen
http://m.youtube.com/watch?v=wKhu42yWLXY
Cateram nose
I got this frame from video
then i I drawed the frame by tracing the shape of the frame
So I got this shape side view
http://www.newsf1.it/
Atreydes
Re: 2014 Design
Hello everyone I am an Italian with a passion for technical f1
http://www.omnicorse.it/magazine/33657/ ... lla-scocca
(Giorgio Piola)posted this rumor about the Force India
