Thank you for the giyfSebp wrote:Maybe this helps:
http://www.giyf.com/![]()
http://en.wikipedia.org/wiki/Suspension_%28vehicle%29
http://en.wikipedia.org/wiki/Anti-roll
Basically, if your inner wheels have sufficient (however you want to define that) contact with the road surface, your cornering stiffness is good. The better your contact, the more lateral acceleration your car can cope with, the higher your maximum cornering speed (if the surface has no bumps).
How about the non-linear region?Lycoming wrote:That's not the definition I learned![]()
For small slip angles, the tire's lateral force increases linearly with slip angle. The slope of this relationship in the linear region is the cornering stiffness; steeper slope = higher cornering stiffness.
If the non-linear region means the tire cant produce more lateral force due to too much slip angle right? And id ita really non-linear, how are people able to drift cars if its that unpredictable?Lycoming wrote:Then, it's non-linear and can't be described by a single value for slope? you can still determine a cornering stiffness value by taking slope out of the data between data points, but it's not a very useful thing to do outside of the linear region, wherein it has certain performance implications.
Yeah, but what does this have to do with the thing you just said?
How can you predict something that doesnt go up/down linearly?Lycoming wrote:non-linear does not necessarily mean unpredictable.
I am also confusedSebp wrote:As I said I got confused![]()
Shame on me
You run loads of tests and establish a working mathematical model for your parameters.Erunanethiel wrote:How can you predict something that doesnt go up/down linearly?Lycoming wrote:non-linear does not necessarily mean unpredictable.
No I mean when you are driving it, like driftersSebp wrote:You run loads of tests and establish a working mathematical model for your parameters.Erunanethiel wrote:How can you predict something that doesnt go up/down linearly?Lycoming wrote:non-linear does not necessarily mean unpredictable.
