Most peculiar suspensions.
xpensive
xpensive
214
Re: Most peculiar suspensions.
Chaparral 2H DeDion rear suppension;
Belatti
Belatti
33
I cant believe anyone has not posted this:
The new Merc Y shaped front lower 'wishbone' reminds me of the FW-16 rear suspensions. But i'm not sure; did that Williams have an Y shaped upper arm at the rear, like the Merc, or was it just a normal triangle with a larger trailing part ? what do you think ?
No triangle here
ralt12
ralt12
Here you go….Didn't see this every day...
Jersey Tom
Jersey Tom
ralt12 wrote:Here you go….Didn't see this every day...
http://www.nelsonmotorsports.com/Nelson ... 36_IMG.jpg
Slicks with standing water? Yeah tell me about it!
humble sabot
27
CBeck113 wrote:http://imgur.com/a/B3UhL#30
http://imgur.com/a/B3UhL#31
Edit: Wasn't pulling the images from Imgur, so I switched them to [url].
Bloody Mary is one of the best things in the world.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
thisisatest
thisisatest
xpensive wrote:Chaparral 2H DeDion rear suppension;
http://i120.photobucket.com/albums/o199 ... C_2653.jpg
holy cow. is that bronze circle on top a pivot? to set toe? does the toe change dynamically, or just for static adjustment? the boxed in structure looks very stiff, but the ends (and the middle pivot area) look like solid aluminum pieces. must weigh a ton.
i guess there was a bunch of stuff hanging off the back of the car, hence the need to make the DeDion tube go up n over.
Tim.Wright
330
Belatti wrote:I cant believe anyone has not posted this:
http://www.golpedirecto.com/wp-content/ ... -F2012.jpg
Probably because there is absolutely nothing peculiar about pull rod suspension.
650
thisisatest wrote:holy cow. is that bronze circle on top a pivot?
lateral location ?
DaveW
DaveW
239
Tim.Wright wrote:Probably because there is absolutely nothing peculiar about pull rod suspension.
Probably not.... But apart from 3 F1 teams (one of which has quickly reverted), can you think of any other examples of such peculiar front suspension geometry? (ducks head in anticipation).
Tim.Wright
330
I don't think anyone are doing anything peculiar with the suspension these days.
Save for the fact that Dynatune Paul suspects that some teams might be running suspension with positive camber gain (i.e. opposite to normal) in order to reduce the roll centre heights.
But thats got nothing to do with a pull rod.
Its been illegal to do anything peculiar to the suspension systems for quite a few years now.
Sebp
You had this one coming :P
No smartphone was involved in creating this message.
Sombrero
Sombrero
126
The very best of active suspension : the FW14B
[youtube]http://www.youtube.com/watch?v=7AME4v3qZkc[/youtube]
DaveW
DaveW
239
Sebp wrote:You had this one coming.
You are quite right....But the geometry does look more likely.
Sombrero wrote:The very best of active suspension : the FW14B
So does that. But the phrase "best of.." is debatable.
The geometry of this also looks more likely (but it did have an alarming rising rate):
... it didn't have a bad active suspension system, either, but I admit to being biased.
Sombrero
Sombrero
126
You're right : the very best of active suspension including both the forerunners Lotus and Williams.
[youtube]http://www.youtube.com/watch?v=xjHNS8Jvz78[/youtube]
The Lotus active suspension story
http://www.gglotus.org/ggtech/activesus ... vesusp.htm
I read somewhere (Peter Wright) that the active suspension was already a "plan B" to fix the issues with the full length ground effect chassis Lotus 80. It was rejected : too soon. "Plan A" was the twin-bodied Lotus 86 "Torrey Canyon" that lead to the Lotus 88.
