Lotus E22 Pre-launch Speculation
Re: Lotus E22 Renault
I find this pic
erlik
erlik
That nose looks very fragile. And than it looks like a different nose than one from picture above?
Nose is new but car look like r29
FrukostScones
163
zioture wrote:I find this pic
[url]https://scontent-b-mxp.xx.fbcdn.net/hph ... _n.jpg/url]
NO, that is NOT THE REAL E22!
Just look at it carefully. Even the nose is not the same like the one from the twitter feed.
Looks like an R27 monocoque with a 2014 stlye nose. 'V' keel font suspensions. Beam wing, R27/R28 air box etc
Right and rear wing have beam wing it's only a show car
Definitely just a car for showing. The front wing has to be from 2009 or 2010.
They just scrapped some parts together.
aral
aral
26
Blackout wrote:It has no KERS mode button for example
http://cdn-3.motorsport.com/static/img/ ... 3/s1_1.jpg
as far as I am aware, there is NO kers button on any car this year, as energy boost is now an integrated system.
Yes. That's what I wanted to say; this steering wheel lost last year's Kers switch/button, so it msut be the 2014 steering wheel.
emmepi27
emmepi27
141
They have 2 different car! But the real E22 is there!!!
I'd need a different picture to be sure, but I believe the 2 tusks are equally long, which means they used a vanity panel to cover up the shorter one.
emmepi27 wrote:They have 2 different car! But the real E22 is there!!!
https://pbs.twimg.com/media/Bf3fF4cCcAAsR6h.jpg:large
Again, That's an R27 monocoque with a 2014 stlye nose. Has a R27/R28/R29 style air box but a 'V' keel font suspension and a hrorizontal coque so it must be a 27.and it has a beam wing, a 2009 FW... just a typical show car made in Enstone and that ressembles the new car.
That's the CFD center of Enstone BTW, not Jerez. So yes 2 different cas in 2 different locations.
Rhodium
25
right picture, is just a nose cone.
if you look better, you can see the ranking for nose cone on the floor.
this picture was be taken anywhere..
i hope you're right, i hope E22 will in Jerez, but, for the moment, no truth
Re: Lotus E22 Pre-launch Speculation
E22 for sure (oval air intake)
Rhodium
25
ha yes, great pic !
thanks.
