Red Bull exceed fuel flow limit, Ricciardo DSQ at Australian GP
beelsebob
beelsebob
85
Re: 2014 Australian Grand Prix - Melbourne
djos wrote:It's quite clear they don't work
What makes that clear? The fact that one team out of 11 disagrees with the result?
to claim they do work properly ignores the fact that Mercedes and Renault powered teams have both been told to turn down their fuel flow rates!
Your logic does not work. None of these teams suggested that it was invalid to turn down their fuel flow rates. In fact, they went ahead and did it, which suggests they think it's entirely valid.
thomin
djos wrote:
thomin wrote: How do you know that they don't work? That is nothing more than an assertion. I have also not seen any evidence that the FIA changed any correction factors during the race. They did so after free practice when they analyzed the data and they did so with every team by increasing the measurement interval.
It's quite clear they don't work, to claim they do work properly ignores the fact that Mercedes and Renault powered teams have both been told to turn down their fuel flow rates!
To suggest that these billion dollar car companies can't accurately measure their own fuel flow while developing and running their engines is simply nuts!
It all depends on the interval of time you look at and at individual spikes in fuel consumption. Who's to say how the teams/engine manufacturers measure their fuel flow and how it compares to the FIA method? Also, the place where the measurement takes place also can make a difference. That's why we need one sensor that is the same for everyone in order to prevent "trickery" as Montezemolo called it before the race.
What you present here as evidence really still amounts to nothing.
djos
115
Toto claimed the adjustment cost them .5 of a second ... Why would Mercedes waste millions of Dollars developing their engines to run at a rate that is illegal and of no use to them?
Mercedes have one of the most advanced F1 engine development organizations ever seen and I doubt the €50k FIA sensor is half as accurate as what they use while developing their engines!
"In downforce we trust"
sAx
sAx
Re: 2014 Australian Grand Prix - Melbourne 13-16th March
beelsebob wrote:
sAx wrote:
beelsebob wrote:... Weigh the fuel before, weigh the fuel after...
Read this argument a few times now and I believe it misses the point. It is not about the mass of fuel left in the tank, it is about the power strategy during the race. A continuous peak flow 100kg/h would mean spending the remaining 30min race period watching from the sidelines. From inspection then, a continuous exceedance in fuel flow would not allow a car to make the hour mark! However, if you could stratgeically burn at higher fuel flow rates (> 100kg/hr) at key periods to increase power to overtake/maintain position (...like Magnussen is catching you!), then switch to fuel conservation engine map, you would not trigger exceedance of max consumption limit as many cars did not require 100kg fuel mass to cover the distance from the start.
The point is that if the fuel flow meter is accurate, the integral of the values it records over the length of the race should be very close to the final fuel usage. It should be possible to demonstrate it's inaccurate by taking that integral, and seeing if it matches the fuel consumed.
Such an integral does not answer whether >100kg mass has been used, which was your initial point.
Integrity, Trust, Respect.
Follow me: http://twitter.com/#!/sAx247
djos
115
I'm not claiming I have evidence, I'm just arguing thru the logic, it seems all the teams have been told to turn down their maps, and while F1 teams will always try to use every inch of the rules to gain advantage, in this case I don't see all 3 engine makers and every team being wrong.
It's only redbull with the balls to stand up to the FIA - they really have nothing to lose as they didn't expect to be fighting for a podium in the first place.
thomin
While I still disagree for the reasons I gave above, even if you were right, it would be completely beside the point. If the FIA sensor was less accurate, then it would still be less accurate for everyone, so nobody is at a disadvantage...except of course when Red Bull decided to ignore the sensor against the explicit orders of the FIA, at which point they put every other team at a disadvantage.
ecapox
No, its only redbull who didn't adjust their maps during the race, which in turn led to a DSQ....and then they complain. The smart thing would have been to do what all the other teams did and THEN complain.
Hail22
144
News in: Australian GP Corporation considering legal options against the FIA as apparently the:
"product of this Grand prix was not what we signed for and the sexyness is lacking, we signed up for a completely different product and will work in conjunction with the FoM, yes sound was part of the contract to which the Australian GP corporation agreed to"
This was a live press conference so I'm sure it will be published on news sites soon.
Either Bernie E is using his pawns to start a revolt against the FIA or genuinely the Aus GP corporation are doing it on their own steam due to a contractual breach.
Gilles Villeneuve
stuartpengs
Slightly off tangent, but I thought the pits/car comms was much clearer than last year. Could actually understand the drivers. I watched the race on BBC as I couldn't make the Sky live race, and if I'm honest I was disappointed with the lack of noise from the engines. I'm hoping its a broadcast feed issue that needs some fine tuning, they certainly sounded more audible during the testing. Maybe I just need to crank the TV up a bit. :oops:
langwadt
langwadt
35
it is the same for everyone so it doesn't really matter, the measuring stick that counts is FIAs
if the FIAs sensor is consistent but say 2% high for everyone, they can all just pretend the regulations says 98Kg/h
djos
115
This is F1 not formula Ford!
beelsebob
beelsebob
85
sAx wrote:
beelsebob wrote:
sAx wrote:Read this argument a few times now and I believe it misses the point. It is not about the mass of fuel left in the tank, it is about the power strategy during the race. A continuous peak flow 100kg/h would mean spending the remaining 30min race period watching from the sidelines. From inspection then, a continuous exceedance in fuel flow would not allow a car to make the hour mark! However, if you could stratgeically burn at higher fuel flow rates (> 100kg/hr) at key periods to increase power to overtake/maintain position (...like Magnussen is catching you!), then switch to fuel conservation engine map, you would not trigger exceedance of max consumption limit as many cars did not require 100kg fuel mass to cover the distance from the start.
No it wasn't. If you read it like that, then I phrased it badly, sorry.
Sulman
Sulman
Hail22 wrote:News in: Australian GP Corporation considering legal options against the FIA as apparently the:
The 'sexyness' was lacking? What on earth does that mean? Was it really less sexy than last year, or is this all about Ricciardo?
Sulman
Sulman
stuartpengs wrote:Slightly off tangent, but I thought the pits/car comms was much clearer than last year. Could actually understand the drivers. I watched the race on BBC as I couldn't make the Sky live race, and if I'm honest I was disappointed with the lack of noise from the engines. I'm hoping its a broadcast feed issue that needs some fine tuning, they certainly sounded more audible during the testing. Maybe I just need to crank the TV up a bit. :oops:
I thought there was far too much reverb, and all the midtones were clipped. This was an issue last year at some tracks; it sounds like the inside of a Pringles tin.
langwadt
langwadt
35
and the rules are very clear, they must flow less than 100kg/h as measured by the FIA sensor, what the team measures
isn't relevant. The FIA sensor is the standard when it says 100 it is 100
The teams are given the data and fair warning so they can adapt their systems to comply with that
