I wonder if each wobble is triggered by downshifts of the gearbox while under heavy braking.Emerson.F wrote:Hey guys was this normal? I was scared that wing would just break off at any moment.
https://31.media.tumblr.com/3796a3e213f ... o1_400.gif
My guess is a combination of wind direction, wind speed and road vibration caused this. I don't recall seeing this later on the race or on other parts of the circuit so it was probably just a freak occurrence.YUL-F1 wrote:I wonder if each wobble is triggered by downshifts of the gearbox while under heavy braking.Emerson.F wrote:Hey guys was this normal? I was scared that wing would just break off at any moment.
I was thinking the same, but i may just be bumpy because the rear wing is attached to the rear suspension arms and the vertical strides next to the exhaust.YUL-F1 wrote:I wonder if each wobble is triggered by downshifts of the gearbox while under heavy braking.Emerson.F wrote:Hey guys was this normal? I was scared that wing would just break off at any moment.
The wing can not be attached to the suspension.Emerson.F wrote:I was thinking the same, but i may just be bumpy because the rear wing is attached to the rear suspension arms and the vertical strides next to the exhaust.
Williams was looking equally bad.. I am sure you all have seen this:YUL-F1 wrote:I wonder if each wobble is triggered by downshifts of the gearbox while under heavy braking.Emerson.F wrote:Hey guys was this normal? I was scared that wing would just break off at any moment.
