Electronic brake control in 2014
armyk
armyk
Re: Electronic brake control in 2014
ABS would be useless. If they block wheel they block front tires...
Maybe there is option that they can harvest energy from Engine into the battery while accelerating to prevent slipping wheels (reduce power)
autogyro
autogyro
53
armyk wrote:ABS would be useless. If they block wheel they block front tires...
ABS is a natural result of the fly by wire system as is traction limiting, if you design it right.
armyk
armyk
My point is, that it would be useless as ABS, but could be used as TC.
techF1LES
176
© Giorgio Piola
OO7
OO7
171
Would it be possible to have a system where the driver is in direct control of the MGU-K while braking?
The brake line is connected to the rear brake calipers and a clutch system for the MGU-K. As the driver presses the brake pedal the clutches are forced together which allows the MGU-K to spin up. At saturation (governed by the driver selected setting), valving in the brake lines begin to transmit pressure to the rear calipers.
langwadt
langwadt
35
Blaze1 wrote:Would it be possible to have a system where the driver is in direct control of the MGU-K while braking?
the mgu must be permanently attached to the crankshaft so if they use a clutch it would be the main clutch,
they can vary the harvesting electronically it's all done by a computer, mixing the rear brakes and the mgu harvesting via the mgu controller and the rear brake control valve
autogyro
autogyro
53
ABS and Traction limiting by another name.
