that gif is not clear, if you focus on Premiere logo it moves a lot, best take an onboard video and you'll see it
http://www.dailymotion.com/video/x1y983 ... ndo-alonso
here is that pic againmodbaraban wrote:Why not kindly post that gif here?RH1300S wrote:Yes it does flex - you can see it pretty clearly in the gif.
All biplane front wings try to emulate the difurer's behavior, only for the front part of the car. I cannot explain it more, because I do not know how excactly the do that, but that's the information I have from a team's aerodynamist. Sorry...zac510 wrote:Would you please kindly explain that?s91066 wrote:Think about it as a second defuser...modbaraban wrote:I don't get it. What's the point in making it flex while it doesn't generate much less drag. The mid part is very narrow and the angle.... c'mon...
what does it change?
thanx very much! It's ABSOLUTELY OBVIOUS here.siskue2005 wrote:And the video > this is more high quality than the youtube videos http://rapidshare.com/files/30809876/Fo ... nboard.rar
I saved the initial clip and opened it into photoshop and compared the position of the wing end-plates (in each frame relative to the level of the aerial).... and it looks more like the wing end-plates are moving down - not just the new upper element. Only a slight flex would need to happen - and an amount which might be well within rule tolerances.RH1300S wrote:...In McLaren's wing - the main plane does not APPEAR to flex, but the middle part of the new "bridge" seems to dip under load.
As I said above, I'm not so sure it's flexing. It moves down, yes, but from a closer look it seems to do this because the ends of the main front wing (which it's attached to) bend down slightly under high speed like they do on every other team also.ginsu wrote:Yeah, I think it's a joke that the FIA don't care about this, and yet they went out of their way to define the Renault tunable mass damper as a 'moveable aerodynamic device'.
Obviously, if a part is flexing significantly by natural aerodynamic forces then it's moving...
