Top marks for the trickery thenG-Rock wrote:Guys, guys, don' you see that this Ogami character is just jerking you around. He's just bored and wants to confuse people. His questions are so stupid that he shouldn't even be on this website.
If he can't understand that a car at full throttle can achieve the same speed as a car a part throttle (in a draft) then there is no hope for him.
You're correct. One RPM=one speed. Think about it. There's nothing variable between the engine and wheels, as long as you're on a same gear.Ogami musashi wrote:I know what draft is, what i want to know is the relation of Power to RPM and torque.
So i repeat my problem is to know why one RPM=one speed (assuming we are on the same gear shift and gear ratio).
Thanks for finding the way the revs are limited in an F1. I missed that oneG-Rock wrote:Yes, thankyou. I think we are all on the same page now. I hope Orgasmi is happy with our input and that the mystery of Rpm, speed and drafting can be put to rest or maybe we're not thinking out of the box. Is he is experiencing clutch slippage at high speeds which then in a draft would ease the power going through the clutch to the transmission, at which point the clutch would hook up again, thus lowering the rpms? Then when he gets out of the draft the clutch starts to slip again and voila, rpm's increase relative to road speed. This all happens without adjusting the throttle. What do you think of that?
G-Rock (jerk)
I need to correct my statement. It's true that if identical cars ran the same RPM, they would stay on station with each other, neighter gaining or closing. You were talking about a 19K rpm limited engine, while I was referring to NASCAR, where the limit is power produced. The trailing car may be running just 25 RPM quicker than the lead car, but it is going faster.DaveKillens wrote:Let's assume a steady state drafting scenario, such as NASCAR at Talladega, with just two cars. Let's leave out such factors as acceleration and consideration for braking.
The lead car is running flat out, top gear. The car directly in the draft would run identical RPM, but under full throttle would close on the lead car, until they collide. To stay in station, the car in the rear would have to ease off the gas (lessen the power produced) just to maintain the same distance.
I hope that helps.
