As you see here for a hillclimb Subaru Impreza I designed 2 years ago, the lift coefficient suffer from drops as the cells number increases (these are the "holes" I am talking about).
3.5m cells
5.7m cells
10m cells
21.3m cells
45.1m cells
59.4m cells
80m cells
To this day I still have no explanation of what is really happening here. One would tend to trust the results with higher cell numbers and cleaner residuals which is the reason why I chose to run all this project with the settings of the 10m cells model, but I am still very surprised about the variation of results.
I used a k-epsilon solver, steady state, with rotating wheels, an air speed of 100mph and big control volume so no blockage involved, and I had a very fine control volume right behind the car to capture the wake precisely.
This issue came to me recently with the KVRC 2015 competition so I was wondering if this is something common or just with me (and the settings I am using). My understanding is that some aero phenomenon (vortices) are badly captured with some models and how the cells are built, but that is not really a scientific answer.
You also get the case where you do a minor adjustement to the car (changing slightly an end plate for example) and the results vary by something like 20% which is absolutely not correct. I think this is linked with the issue I am mentioning here.
Anybody got the answer to this behavior?
P.S.: The models above 25m cells were ran on a cluster with tons and tons of RAM, there is no way I could have done this on my computer even with 32GB of RAM!
