Khamsin Virtual Racecar Challenge 2015
julien.decharentenay
Re: Khamsin Virtual Racecar Challenge 2015
I think you are probably better places to advise on the number of cells. My take is that it is around 1 to 1.5 millions cells, but I haven't really spend a lot of time testing it...
By the way I forgot to mention that I tried to load an openfoam result using ParaView from the OCCFD v1.0. The raw size of the results is getting too much for my computer. I will probably have to find some workaround such as converting the results to VTK format prior to loading them into ParaView and select only specific variables. Let me know how you guys are going with it.
RicME85
52
You not still using that Pentium 4 are you?
machin
162
cdsavage wrote: COG will definitely be within a percent or two of 45 front / 55 rear. We're just waiting on confirmation from Richard (virtual stopwatch).
I can confirm 45:55 front to rear weight distribution, So you should be aiming for the same aero balance. I'll get some aero vs lap time charts sorted out over the weekend.
RicME85 wrote:You not still using that Pentium 4 are you?
It wasn't worth it trying to get it from Oz to UK - so it has made a one-way trip to the recycling. I upgraded to a Core-2 Duo @ 2.4GHz - probably just made it into the late 2000s technology...
CAEdevice
52
Maybe you will not believe it, but I have a Pentium4 still working in my office :)
Xwang
Xwang
29
Is an intel i7 laptop with 16gb ram enough for this cfd calculations?
RicME85
52
yeah, will take time but it will definitely work
MadMatt
MadMatt
125
RicME85 wrote:yeah, will take time but it will definitely work
Take time? On what do you base your conclusion?
CAEdevice
52
16gb ram and i7 are a very good hardware for kvrc cfd simulations (less then 20x10^6 cells).
MadMatt
MadMatt
125
CAEdevice wrote:16gb ram and i7 are a very good hardware for kvrc cfd simulations (less then 20x10^6 cells).
Agree. The only thing I would advice is to pay attention to heat. Having your CPU flat out for a certain duration can cause it to overheat quite badly, and eventually shut down (or worse), so while you are running your simulation, just make sure you lift (at least the back of) your laptop to allow air to enter the fan underneath your machine.
Usually putting a book lifting the rear of the laptop is enough.
MadMatt
MadMatt
125
How long does it take to complete a simulation for those who have performed one using OCCFD 1.0?
CAEdevice
52
MadMatt wrote:How long does it take to complete a simulation for those who have performed one using OCCFD 1.0?
With the last release (1.0) I don't know exactly, I estimate less than 3h
Gents, there is a drastic increase in computational time with v1.0 compared to the earlier version. It is all to do with the mesh size... The light version should be a lot faster...
It is not easy to find the "right" compromise between mesh size and computational time #-o
I have put out a very minor upgrade - increase the mesh limit following a query from CAEdevice. No other changes...
http://www.khamsinvirtualracecarchallen ... .0-001.zip
