bridgestone:
michelin:
I'm no tire expert, but it could be both. There's always talk about having different type of compounds.rumpelstulskin wrote:Hey I wanted to know something about tyres if anyone has any knowledge in that department. The point of downforce is, I believe, to get more grip on the road and hence get better speeds. In which case the better dry weather tyres would be expected to last longer and not weather and loase threads and grip. In which case how is michelin's dry tyres a better deal than bridgestone's since they visibly do disintegrate faster. Is Michelin's advantage in width or texture?
So this basically explains why Renault had a difficult time adapting to the single supplier rules in '07 right. Their setup and development was still focused and concentrated on how the Michelins "worked", even though they are now on Bridgestones. Did Honda have the same adverse effects by the switch to BS? As we have seen all of their aero and weight distribution problems this season.scarbs wrote:The trait you are trying to understand is 'degradation' which is the tyres performance over its life. Michelin have a different compund, construction and size of tyre to bridgestone. They also demand different suspension, weight distribution and traction control settings.
The '08 season will have a drastic effect on tire wear and strategy then, because tires will be more prone to earlier degredation due to the fact that Traction Control will not be reducing slipping and sliding.scarbs wrote:The less downforce or for whatever reason the amount the car slides on (or spins) its tyres affects the wear. Dry weather tyres are designed to last only the length of the expected stint in the race, they should be only just starting to lose grip as the pitstop is called, by this stage the tread block can be expected to be ripped and worn
When TC was reintroduced in 2001, Michelin engineers actually assumed that tyres would wear faster because TC allows the rear tyres to be used more "on the edge", so to speak. In other words, TC allows more slip without skidding, not less.mx_tifosi wrote:The '08 season will have a drastic effect on tire wear and strategy then, because tires will be more prone to earlier degredation due to the fact that Traction Control will not be reducing slipping and sliding.
Correct. In fact traction control at Renault for instance was configured as such that TC would try to operate the tyre in a 2% slip ratio since that proved to be the optimum.joseff wrote:When TC was reintroduced in 2001, Michelin engineers actually assumed that tyres would wear faster because TC allows the rear tyres to be used more "on the edge", so to speak. In other words, TC allows more slip without skidding, not less.mx_tifosi wrote:The '08 season will have a drastic effect on tire wear and strategy then, because tires will be more prone to earlier degredation due to the fact that Traction Control will not be reducing slipping and sliding.
