http://www.mercedesamgf1.com/en/car/pu106a-hybrid/ of the 2014 engine:
Can anyone shed light on this?
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
That video clearly shows a compressor housing at the front of the engine. What is especially interesting is the A/R ratio of the compressor housing. It has a very large diameter. The turbine housing is much smaller in comparison, so it seems there is some method of varying the speed between the turbine and compressor.hemichromis wrote:http://formulafreak.kinja.com/craig-sca ... 1656299441
So it looks like Mercedes were trying to mislead their rivals with this picture!
I do not think so. It's not different than other turbochargers. Maybe except the one which is not working properly.riff_raff wrote:(...) What is especially interesting is the A/R ratio of the compressor housing. It has a very large diameter. The turbine housing is much smaller in comparison, so it seems there is some method of varying the speed between the turbine and compressor.
thats against the rules. the compressor and turbine have to spin at the same angular velocityriff_raff wrote:That video clearly shows a compressor housing at the front of the engine. What is especially interesting is the A/R ratio of the compressor housing. It has a very large diameter. The turbine housing is much smaller in comparison, so it seems there is some method of varying the speed between the turbine and compressor.hemichromis wrote:http://formulafreak.kinja.com/craig-sca ... 1656299441
It is difficult to judge the A/R visually. The reason the Mercedes compressor looks so big is that the diffuser is radial. Most turbocharger compressor housings are "folded (rolled)" to reduce the outside dimension. Mercedes packaging has allowed them to avoid this step. Here is a comparison of the two shapes.riff_raff wrote:That video clearly shows a compressor housing at the front of the engine. What is especially interesting is the A/R ratio of the compressor housing. It has a very large diameter. The turbine housing is much smaller in comparison . . . .
gruntguru wrote: โ23 Dec 2015, 03:01It is difficult to judge the A/R visually. The reason the Mercedes compressor looks so big is that the diffuser is radial. Most turbocharger compressor housings are "folded (rolled)" to reduce the outside dimension. Mercedes packaging has allowed them to avoid this step. Here is a comparison of the two shapes.riff_raff wrote:That video clearly shows a compressor housing at the front of the engine. What is especially interesting is the A/R ratio of the compressor housing. It has a very large diameter. The turbine housing is much smaller in comparison . . . .
http://i.imgur.com/E5m4esT.png
