Wazari
635
Re: Honda Power Unit
godlameroso wrote:I'm sure Honda's turbos are manufactured exactly as Honda wants to the extent it might as well be in house. Furthermore, Honda has a lot of subsidiaries such as Kehin, Modulo, NOK, which although separate companies are essentially just an arm of Honda. I think their power unit is as 'in house' as Mercedes.
*I wonder who makes their battery pack, I want to say Panasonic but I doubt it.
Either A123Systems or Yuasa
-- Honda Soichiro
mikeerfol
68
I guess Yuasa would make sense since they're working together in BTCC.
nevill3
16
ME4ME wrote:
nevill3 wrote:Don't forget the new Turbocharger will not use any tokens because of the new requirement to vent the wastegate flow through a separate exhaust pipe.
I strongly believe that to be incorrect. Turbocharger design changes will definitely cost tokens.
Not only the turbocharger but the energy recovery systems are token free upgrades this year
http://www.f1technical.net/news/20211
According to the letter Mercedes, Ferrari, Renault and Honda will be permitted to use 32 tokens insted of the planned 25 contingent. In the following years 20, 15 and 3 tokens will be at their disposal. That should open up possibilities for struggling engine manufacturers to close in on the field leading Mercedes.
On top of the tokens' quantity, FIA permits the teams to work on every part of the turbo and the hybrid system.
The only issue the teams have is the timescales required to maximise any advantage they could gain from this "token free" upgrade. The FIA only clarified the new rules in late December and the teams must have already planned a development route to maximise their token use for 2016.
I presume once the engines are homologated prior to the first race then this token free upgrade/change will be set in stone and any further changes would require the use of tokens. Has anybody seen the exact documentation regarding this change and does it stipulate a time frame? If no date is mentioned I can see a loophole ready to be exploited!!
hemichromis
hemichromis
If that's true its very interesting for Honda who seem to have a good ICE but need improvements to turbo and ers to progress.
Not so good for renault who's weakness seems to be the ICE
drunkf1fan
drunkf1fan
I'm fairly certain that isn't saying they are free from token costs. Year on year more parts are supposed to be frozen limiting what the tokens can be spent on. They are saying along with the increased tokens nothing within the hybrid/turbo is frozen so any part of it can be upgraded.
nevill3
16
After further research it seems that only Honda have a token free upgrade due to the design of their turbo casing being incompatible with the new wastegate regulations but it is only worth two tokens.
Re-reading the clarification letter linked to before allows the teams to work on items that I think were due to be "frozen" this year rather than giving the teams unlimited ability to make wholesale changes to their turbo and energy recovery systems token free.
I found a list on F1Fanatic detailing the previous proposal for freezing engine components and the compressor was on that list.
However for 2015 three items (with a total weighting of five tokens) are frozen in specification and cannot be modified. These are:
Upper/lower crankcase: Cylinder bore spacing, deck height and bank stagger
Crankshaft: Crank throw, main bearing journal diameter and rod bearing journal diameter
Air valve system: Including the compressor and air pressure regulation devices
The number of frozen items will increase again next year, stay the same in 2017, increase again the following year and significantly increase for 2019 and beyond. Therefore teams may wish to prioritise development on items which will be frozen in specification sooner rather than later.
Craigy
87
McLaren user A123 batteries on the P1. I wonder which part of the team handles it...
Wazari
635
The more I think about it, I'm going to guess it's the A123Systems that McLaren Honda is using. They have a patented nanophosphate design for their batteries that is more suited for the rapid recharging and high temperatures that they are exposed to. I would think McLaren would spec the battery to the supplier to fit their chassis. This is just a guess.
It is also my understanding that the first of the 2016 PU's are being mated to the MP4-31 chassis sometime this week.
-- Honda Soichiro
Joseki
Joseki
Wazari wrote:It is also my understanding that the first of the 2016 PU's are being mated to the MP4-31 chassis sometime this week.
So they are going to test the new MP4-31 on a dyno?
hemichromis
hemichromis
I think the MP4-31 will break the dyno with all the power it will be producing!!!!
Careful now :D [-o<
GoranF1
GoranF1
149
Good news,and very smart choice of words! :wink: Did you "understand" anything else maybe?
Wazari
635
It has been my experience that whenever you mate a new PU to a chassis there are always unanticipated issues. Plumbing, electrical connections, other problems always seem to pop up. I would assume they will be testing the new chassis/PU combination on the dyno soon.
I haven't understood anything else as of now.
-- Honda Soichiro
FW17
189
Wazari wrote: I would assume they will be testing the new chassis/PU combination on the dyno soon.
Where would that be?
GoranF1 wrote:The fact that of current manufactures Mercedes is the only one that builds their TC in-house, is probably a very big advantage for the Germans in this new engine regulations.
The overall turbo design could be in collaboration with Borgwarner though... It just smells of Borg warner - they have been known to try really unusual designs.
