New chicane to be added at Monza?
djos
115
Re: The F1 news FUD topic!
Lol, are they serious?
"In downforce we trust"
Per
Per
35
I haven't read the original story in Gazzetta dello Sport, but this one is explaining what Gazzetta wrote: https://www.road2sport.com/2016/01/23/f ... formula-1/
According to this article the reason for this additional chicane is so that LMP1 and SuperBikes can go straight at the first chicane, which is a bit too tight for them now. Currently if you send them straight through the first chicane, they are too fast at Curva Grande to be safe.
The current layout of Curva Grande will not disappear, this chicane will just be the 'alternative route' for some classes. So basically F1 would have the choice to use the new layout, without first chicane, or the old one.
Facts Only
Facts Only
188
This sort of thing really naffs me off (not the post but the sentiment of certain people in Motorsport), if the chicane is too tight then the car hasn't been designed properly. Its not the tracks fault is it? Monza has been like this for years and on the calender long before the cars/bikes in question were designed. The cars should be designed for the competition they are entering, not the other way round.
Tim.Wright
330
Re: New chicane to be added at Monza?
I don't necessarily buy that as a reason eithet. There is so much room at the first chicane now that if they wanted to open it up they could.
theblackangus
theblackangus
Tim.Wright wrote:I don't necessarily buy that as a reason eithet. There is so much room at the first chicane now that if they wanted to open it up they could.
+1
Why change another part of the track if the 1st chicane is the issue?
I always thought it was too tight anyway! Just fix the 1st chicane.
FW17
171
A nice uphill chicane.
Not a bad idea.
I wonder what the transition from the regular circuit to the new section would be like
Per
Per
35
The concern about the current first chicane is not the technical challenge for car and driver, but the funnelling effect especially at the race start. In F1 it's already one of trickiest first corners of the season, and LMP1 cars are an even worse nightmare for wheel-to-wheel racing.
Just explaining the rationale behind this possible new chicane, not saying I agree with it.
Moose
Moose
52
Looks like about the worst possible place you could put a chicane for F1. A tight overtaking corner immediately after a high downforce curve doesn't typically work, because the overtaking cars wash out through the prior corner. Hopefully F1 uses the existing layout rather than the alternate one.
DiogoBrand
74
Well, they say they want to make this layout to eliminate the first chicane, and the new chicane seems so close to what is now the second that they'd probably be able to go straight on that one too, so they'd actually be turning two chicanes into one, which would be a good thing. In general I'd still prefer the current layout, mainly because they'd be eliminating the fastest turn in the circuit, but if this chicane means they'd be eliminating the other two it wouldn't seem that bad.
Vasconia
Per wrote:I haven't read the original story in Gazzetta dello Sport, but this one is explaining what Gazzetta wrote: https://www.road2sport.com/2016/01/23/f ... formula-1/
Well, it doesnt sound so bad. I mean, if drivers can try both and decide, with some common sense , which one is better it could be interesting. But common sense is a treasure In F1 those days... :roll:
strad
117
Couldn't agree with the sentiment any more.
For far to many years the constructors have demanded changes to tracks to suit their cars rather than building cars to handle the tracks they have.
BTW I dislike the idea of this new chicane. :lol:
Sir Stirling Moss
langwadt
langwadt
35
mandatory joker laps in f1? . . .
Cold Fussion
Cold Fussion
93
Obviously it makes far too much sense to address the problem of the first chicane being too tight (so long as you ignore the illogical stance of cars not being designed for circuits they intend to race at) and to instead install another chicane arbitrarily. I would actually be in favour of the first chicane being re-profiled, perhaps to be more similar to the original first chicane at Monza, or the old bus stop at Spa.
strad
117
or take it out entirely. :wink:
Sir Stirling Moss
