[KVRC] Khamsin Virtual Racecar Challenge 2016
RicME85
52
Re: Khamsin Virtual Racecar Challenge 2016
Just noticed, its the extended volume used in the last version of last years rules isnt it
cdsavage
cdsavage
19
RicME85 wrote:Further to what etsmc said, is this correct?
https://i.imgur.com/0DYpRjp.png
That's the offset guide.
RicME85
52
Yeah...see above :D
Have just imported everything and noticed it seems to be the same as last year except for an extra 15mm above the front wheels and one of the floor guides is just in the diffuser area.
cdsavage
cdsavage
19
CAEdevice wrote:
cdsavage wrote:First version of the guide parts released for full participants and the introductory subclass, available on the KVRC site here: http://www.khamsinvirtualracecarchallen ... nge-2016-1
I opened the CFD parts: it seems that there is a scaling issue with the supensions (the wheels are ok for both scale and location). Could you check it? I'm not sure if the problem is in the original file or in myu import process.
For the STL files or the STEP file? When I open the STL files in Paraview the scale appears to be correct. The scale is not ideal, we should really be using 1 unit = 1mm as this seems to be what most modeling packages expect, but this is how we did it in 2015.
RicME85
52
etsmc wrote:well there be a sketchup file supplied?? only reason i as is when importing in to sketchup some of the faces are missing and the suspension template looks alot more basic than last year. if this is how its meant to be then i will carry on.
https://www.dropbox.com/s/ite0b11oq8nuh ... s.skp?dl=0
cdsavage
cdsavage
19
Thanks Richard. I'll make sure to include a SKP next time.
CAEdevice
52
STL: it happened after importing wheels and sups together (maybe it depends on my cad)
CAEdevice
52
Here is the article I wrote about a test with a different software than OpenFOAM. It involves my 2015 car and I also wrote about KVRC.
http://www.caedevice.net/kvrc/test-karalit-3-0-cfd/ (english version available in about a week).
RicME85
52
CAEdevice wrote:
cdsavage wrote:
CAEdevice wrote: I opened the CFD parts: it seems that there is a scaling issue with the supensions (the wheels are ok for both scale and location). Could you check it? I'm not sure if the problem is in the original file or in myu import process.
Seemed fine when I imported all the wheels and both suspension parts in to the same Sketchup file
machin
162
CAEdevice wrote:Here is the article I wrote about a test with a different software than OpenFOAM. It involves my 2015 car and I also wrote about KVRC.
http://www.caedevice.net/wp-content/upl ... 00x445.jpg
Nice pictures... I just need to find my Italian phrase-book now! ;-)
CAEdevice
52
Thank you! Don't worry about the text, it is written for Google not for humans :) The pictures explain everything completely.
etsmc
etsmc
Thankyou
CAEdevice
52
Stay tuned... in the afternoon I'm going to reveal something about the CAEdevice 2016 car (MP004A). I'm not sure if it will be used in the "High DF" races (first two races), since I'm considering the "introductory class" if the release of OCCFD (with "cooling option 2" simulation) will be released too late. Anyway, I'm going to use the MP004 in the last three ("efficiency") races.
EDIT: Here I am :)
This is the new car, MP004B (a "parametric" evolution fo the MP003B, modeled with SolidWorks). Consider that the sidepods and the cooling inlets can deeply vary. At the moment they are dimensioned with an external CFD tool and they are "option 2" compliant. As I wrote before, I would need to develop it with OCCFD 1.2. In case it will be ready to late, I'll switch to "option1" or to "introductory category"- As soon as possibile I will update with some other pictures the CAEdevice thead and my official website.
PS: For the staff: feel free to use any image for the KVRC website and for any other use.
AratzH
Veeery nice looking CAEdevice!!
I was wondering, what flow/pressure drop or velocity/pressure drop curve and porosity did you use for your tests? I am having some trouble to comply with the rules with the parameters I am running...
MVRC -> TF
variante
139
Looks good...a nice evolution of last year's car. I spot a couple of details that i'm going to use on my car ;)
Why the black livery?
