Mercedes W07 Speculation Thread
a1b2i3r45
Re: Mercedes W07 Speculation Thread
Thunders wrote:Aaand Merc also has a fire up Video:
https://twitter.com/MercedesAMGF1/statu ... 6488736768
Clearly visible the 2 Wastegae Pipes.
Renault opted for a single sideways exhaust waste gate tailpipe and merc went with two underneath the main exhaust. Can anyone shed any light on what might be the repercussions ?
Ozan
Ozan
I was expecting 2 upper side wastegate pipes but they went with 2 down side pipes.
Samraj_official
Apparently Mercedes leaves the choice of the Exhaust configuration to itscustomers
http://www.gptoday.com/full_story/view/ ... _Mercedes/" target="_blank" target="_blank
Mercs positioning
Renaults positioning
Gridlock
30
Anything possible in terms of manipulating wastegate flow to seal or energise the diffuser? You'd put the exhausts low in that case.
#58
diego.liv
diego.liv
Whether the 2 pipes are over/under/each side of the exhaust, the structure shouldn't change the balance of the car, correct? But if i want to maximize the main gas flow, i'd put those two wastegate pipes like Mercedes did. Even if they were at each side of the main pipe, their gases would interfere with the main one
Edit: I still think this won't be the final configuration come melbourne-during seaon. Even though, the two of them stay under
Jolle
Jolle
133
diego.liv wrote:Whether the 2 pipes are over/under/each side of the exhaust, the structure shouldn't change the balance of the car, correct? But if i want to maximize the main gas flow, i'd put those two wastegate pipes like Mercedes did. Even if they were at each side of the main pipe, their gases would interfere with the main one
With Mercedes showing it so prominent, I think we can assume they came up with something very clever and this is just to throw everybody off.
Or you know, there is nothing to be clever about, no silver bullets available and since there's no real performance to be gained with, you could just as well show it.
dren
227
The regulations don't allow for anything 'clever' in this area. We'll see similar variations to this Mercedes layout on all of the cars.
Honda!
WaikeCU
Imagine those aren't the pipes at all...
The engine is put somewhere out of view with the camera just pointing at random tubes that aren't even on the car! :lol:
Drica
WaikeCU wrote:Imagine those aren't the pipes at all...
But you can see the hot air exiting the exhausts, so yeah, not a fake
Ferraripilot
21
I'm most interested in seeing if W07, or all teams, mimic Ferrari's radiator solution, and the direction Ferrari go with it this season. Aside from that, I am not expecting W07 to be hugely different than W06. We could almost call it W06-b.
diego.liv
diego.liv
Ferraripilot wrote:I'm most interested in seeing if W07, or all teams, mimic Ferrari's radiator solution, and the direction Ferrari go with it this season. Aside from that, I am not expecting W07 to be hugely different than W06. We could almost call it W06-b.
Didn't Mercedes have a cooling system solution similar to this year's Ferrari, the only difference being V-engine compartment and (/that obliged Merc to have) the Canada update (engine cover bulk at the very rear)?
SiLo
139
I think he meant the fins behind the radiators to keep airflow attached more easily, increasing internal flow and hence, making the radiators more efficient.
Felipe Baby!
LightningLewis
LightningLewis
Mercedes has posted a new video on their Facebook page dubbed "WeAreW07".
Here is a snapshot from the video: Image
Courtesy of MERCEDES AMG PETRONAS
Doesn't it look a little bit different than the W06 (the nose)? Or is it just an illusion?
De Jokke
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
