Mercedes W07 Speculation Thread
OO7
OO7
171
Re: Mercedes W07 Speculation Thread
Looks like it is sporting Ferrari SF15-T side pod cut outs on the forward, top, outside sections.
kreuzass
kreuzass
FrukostScones
162
nice huge air intake, as big as TR, only vertically split (ROS pic)....?
SiLo
135
In some pics it looks round, in some it looks like a oval laying on its side... Seems they are moving some cooling to the more turbulent parts of the car (centreline).
Felipe Baby!
228
Those vertical fins by the mirrors are quite longer on this car. They look like there are really effective for the flow going around the middle of the car.
As for the airbox, i think they made a very bold move. They must have been highly optimized from last year and ran out of ideas. Brackley were never the best chassis makers, so maybe they are showing their true colours now, and redbull and ferrari will take back the lead with chassis refinement.
I'm not convinced that they will have the best chassis this year. Something tells me they are putting their chips on engine performance.
Torro Rosso had a really neat oil cooler design last year; with the cooler straddling the top of the fuel tank, maybe merc are trying something similar?
Owen.C93
Owen.C93
172
nevill3
16
Edit...not quite quick enough..... #-o
aleks_ader
90
ringo wrote:Those vertical fins by the mirrors are quite longer on this car. They look like there are really effective for the flow going around the middle of the car.
http://img1.auto-motor-und-sport.de/Tor ... 903195.jpg
I think those version is not reasonable for Merc PU. The front compressor prety well defined and so how prevent that. Why mess with that proven concept.
I think they just "expand" overall volume of rear "rads" witch sits on top of the gearbox. They probably sacrifice the CofG (densier or thicker rads) and some engine cover bulkiness (witch is already there - compare to Honda - bigger due, massive VLIM). They killed 2 bird with one stone:
-fill the void after PU plenum (VLIM) above low positioned turbo. So you need do that anyway, because engine cover is always preferably smooth transient shape. So there is no "death space" - incresed cooling efficiecy per internal volume.
-Provide the areodynamics designer to shrink the sidepod. And expose the option to rearrange or accommodate the flow structure toward diffuzor differently. Use more undercut in that area, use different cooling side exits in connection of downwash and upwash of rear wing (what a heck; whole rear to front domino efect ) etc.
Edit
Blackout wrote:
So it's just black paint... not a heavy undercut...
Blaze1 wrote:Looks like it is sporting Ferrari SF15-T side pod cut outs on the forward, top, outside sections.
Indeed
OO7
OO7
171
Blackout wrote:Edit
The original Sky video quite strongly hints at a prominent undercut.
OO7
OO7
171
Anyone notice the blown front and rear axles?
kreuzass
kreuzass
Yes. What do you think why i have posted the picture of the weel and the wrench? :wink:
In this picture you can clearly see that the wrench is not the same like last year. has changed.
/edit
If there are blown wheels axles i do not know. Maybe. But i do not think so.
OO7
OO7
171
kreuzass wrote:Yes. What do you think why i have posted the picture of the weel and the wrench? :wink:
In this picture you can cleary see that the wrench is not the same like last year. has changed.
/edit
Ahhhhhhhhhh!!!! 8)
kreuzass
kreuzass
In the scetch it looks like blown wheels axles because there is black instead of the nuts with the white tip. Yes.
/edit
To clarify: Posted the picture because something has changed there an not because i saw blown wheels axels!
