2016 car comparison
2016 car comparison
A thread for comparing the 2016 cars from similar angles, i'll get the ball rolling.
3/4 angle now.
Re: 2016 car comparison
Rake angle comparison
Good view of the undercut.
Jef Patat
Jef Patat
Did you do this one yourself? If possible could you make the opposite as well? Would be interesting.
dodds_turbo
Looks like McLaren now have the largest Roll Hoop to rear swoop of engine bodywork. They might have size zero design under the gearbox but that weight is added on up top. Higher centre of gravity?
In comparison to Mercedes W07:
ferkan
ferkan
31
It seems like cars without split turbo are tightest ones :mrgreen: Though, it does seem like STR is a bit longer then others...Mclaren gained a few pounds at the back, and Mercedes looks generally a bit thicker but, seems like it works for them pretty well eh.
Jef Patat
Jef Patat
dot235
dot235
ferkan wrote:It seems like cars without split turbo are tightest ones :mrgreen: Though, it does seem like STR is a bit longer then others...Mclaren gained a few pounds at the back, and Mercedes looks generally a bit thicker but, seems like it works for them pretty well eh.
I thought so too at first, but it looks like Mercedes has similar solution for this to Ferrari. They made a big enough gap below the rear body panels for air to travel through it so they still get most of the benefits of having a tight packaged rear-end.
http://www.f1fanatic.co.uk/2016/03/07/c ... ery-angle/
F1fanatic just did a great thing for us.
McG
-19
Sevach wrote:http://www.f1fanatic.co.uk/2016/03/07/c ... ery-angle/
Bit of a fail. The pictures don't match up.
Finally, everyone knows that Red Bull is a joke and Max Verstappen is overrated.
GPR-A duplicate2
64
