New qualifying format...
Gaz.
Gaz.
Re: New qualifying format...
nevill3 wrote:So just to clarify things, I think the teams do not have to remain on track throughout the sessions, so setting just one really quick timed lap just like they did last year will allow them to return to the pits.
At first I thought they had to remain on track but I think this is incorrect. I guess we will have to wait for the full rules to be sure.
Once they set a time they can sit in the garage, the only difference is that after a certain time if they have the slowest time they are knocked out rather than being able to set another time. We're going to see a lot less action than how it is currently.
Forza Jules
FrukostScones
163
So some drivers definatly won't stay in the garage for certain reasons :mrgreen:
In the end Bernie E. wants to make it the way that no driver can be certain not to get knocked out, so I wonder what the final qualifying regs will look like.
Bernie want make sure that every second of the qualifying the TV recipient is glued to the screen and also that the grid result is shaken up.
Lets see what it will be like.
SteveRacer
I agree Nevill3. That is how I am expecting it to play out. If they wanted more on track action, maybe they should have given them more tires for the sessions. Everyone is trying to save tires for the race so less laps are made during each session.
basti313
basti313
SteveRacer wrote:I agree Nevill3. That is how I am expecting it to play out. If they wanted more on track action, maybe they should have given them more tires for the sessions. Everyone is trying to save tires for the race so less laps are made during each session.
That is a good point. More tires simply means more driving, now that they are more or less ok with engine lifetime.
Regarding the new Q format: On dry Q it will be not different to the past. The Q3 teams set a fast lap at the beginning of Q1 and stay in the garage. In Q2 most teams run twice, the same like last year, maybe the second run a bit earlier. Maybe the teams which are fighting for Q3 may run once more, but the top teams can not afford a third run. So no big changes...I do not bother as I can not see anything bad with this change.
But I think it will be interesting in the wet. On a drying track no one can afford to stay in the pits, they all need to go out and drive. Maybe this will be the biggest benefit of the change, but we will only see it statistically once per season.
Don`t russel the hamster!
Italiano
Italiano
basti313 wrote: But I think it will be interesting in the wet. On a drying track no one can afford to stay in the pits, they all need to go out and drive. Maybe this will be the biggest benefit of the change, but we will only see it statistically once per season.
Yeah, because until now they didn't go out when the track began to dry out.
Do some of you even read what you write?
#Forza Michael #Forza Jules
strad
117
Hmmmmmmmm That was what I thought at first but now I wonder as well :?
Sir Stirling Moss
ChrisDanger
ChrisDanger
26
Yes, the Autosport article in the OP said they need to stay out, but nowhere else does it say this, so I think that journalist was smoking something and playing too much Need for Speed.
djos
115
More tires would only be useful if the gearboxes and PU's weren't so limited.
"In downforce we trust"
mertol
Why not just have normal qualifying but then the drivers throw a couple of dices and add that amount of tenths to their time? If they want to add randomness, do it openly.
Roman
Roman
I dont see how they would run less than they did before. Also now they are only doing the laps they have to do to advance to the next round. It wont change too much...
Gaz.
Gaz.
Roman wrote:I dont see how they would run less than they did before. Also now they are only doing the laps they have to do to advance to the next round. It wont change too much...
Because for many the sessions aren't as long as they were before.
Forza Jules
adrianjordan
Until the rules are published we can't be sure that they don't have to keep running for the whole session....but I doubt it due to the tyre situation...
Favourite team: McLaren
Henk
Henk
It would force drivers to improve every lap though. But that's only in drying conditions because the track improves very fast. In every other situation it makes qualifying more predictable.
djos
115
Henk wrote: It would force drivers to improve every lap though.
which is nearly impossible with the Pirrelli tires.
giantfan10
giantfan10
27
is it not true that the new qualifications need a unanimous vote by the teams before it is implimented? i doubt there will be a unanimous vote.
fromMotorsports.com:
It was therefore significant that at the very bottom of the FIA release, it said: "The wording of the Sporting Regulations relating to this new qualifying format will be submitted to the F1 Strategy Group and F1 Commission."
This means that, for F1's governance procedures to have been followed to the word, the regulations relating to qualifying must go back to the teams, and will only get approved if there is unanimous support.
