Re: Mercedes Power Unit
They got alot of the little details quite well though.
FrukostScones
passive pre-chamber (laser?) ignition in Merc PU
https://translate.google.de/translate?s ... t=&act=url
FW17
184
what is Vorkammerentzündung?
FW17
184
If they are using pre-chamber, should that be considered as direct injection?
gandharva
252
AMUS is talking about a special spark plug that features a perforated thimble. This spark creates some sort of "fat-cloud" in the combustion chamber. It's exposion has enough energy to completely ignite the rest of the mixture. I think this fat-cloud is what they mean when they talk about the pre-chamber-ignition.
markc
FW17 wrote:what is Vorkammerentzündung?
Vorkammer = Pre chamber
entzundung = inflamation
so translated = pre chamber ignition.
GPR-A duplicate2
64
Engine tokens spent
Ferrari 23 (9 remaining)
Honda 18 (14 remaining)
Mercedes 19 (13 remaining)
Renault 7 (25 remaining)
matt21
86
Mercedes has a patent on this kind of ignition.
I have not managed to find a English version yet
dans79
267
gandharva wrote: I think this fat-cloud is what they mean when they talk about the pre-chamber-ignition.
A pre chamber, is a completely different chamber. Google "pre chamber ignition" and you will see a lot of images like this one.
202 105 104 9 9 7
Frank_
Frank_
chamber in the piston crown maybe ? akin to my diesel one
More pronounced plasma arc from the plug?
gandharva
252
http://world.honda.com/history/challeng ... pho_03.jpg
I am absolutely aware of this, but the AMUS description does not point into that direction. According to that AMUS article there seems to be no additional physical chamber. They describe it more like a 2-step ignition process to increase efficiency.
240
Frank_ wrote:chamber in the piston crown maybe ? akin to my diesel one
http://i65.tinypic.com/2ufrfvl.jpg
This sounds more like it to me. There is ignition in that little pocket initially.
Frank_
Frank_
aye :) spark onto the pilot injection, then progressively inject the rest of the fuel into that little fireball in the chamber ?
keeps the heat away from the cylinder walls (thermal efficiency)
OO7
OO7
171
Sounds similar to how a flameholder in an afterburning turbojet/turbofan engine works.
