digitalrurouni wrote:Not sure if this was shared but I read that Hamilton lost his performance as was evident in qualifying because of changes made to the car.
http://www.motorsport.com/f1/news/techn ... rs-792989/
According to that it had to do with managing heat. W
onder what the changes were that made such a big difference to affect him and not Rosberg at all. My theory is since he was messing up under braking, they changed the brake ducts and he was losing temps possibly? Or they turned down the ERS system to not harvest as much to reduce heat? That would maybe stress the braking a bit more and so making him more prone to lockups?
- Normal set up and performance changes that happen at every GP amplified by new track, conditions (temperature) its development and layout? I'm not sure if dramatic brake ducts changes are possible. Brake balance, suspension, wings adjustments etc. yes.
- He crashed in Q (no set up/pace problems there? ) which may affect you later and was not quick in the race, happens. Starting position, traffic, competition (Perez) - you don't jump him after pitstop it's difficult later (race stages and one-stopper), then engine problems, still 0,2 s per lap
, and how he dealt with them made it look worse. He starts 2nd as he should have and it's Merc 1-2 regardless of any other factors. "Turned down the ERS system" - didn't happen.
I think it's working backwards from results. Changes to the car between FP and Q/R happen at every race, how about one driver coped with it and was simply better and the other didn't? Leading helps like in Canada (compare Rosberg-Bottas to Hamilton-Perez). Saying that he lost performance is all wrong, especially "car performance".
