It may work for Mercedes, but it doesn't actually mean it will work for everybody. The people at Red Bull probably have a good idea of how to make it work, but maybe it increases drag too much, which for Red Bull with their Renault power is a no-no.ringo wrote:I'm surprised that no one has copied the multi element barge boards on the merc as yet.
maybe we could see it on the redbull after the break?
I think the "multi barge board" thingy is long developed with the accordance of front wing on w05-06 and finally 07. the front wings on rbr and merc are different in terms of diverting the air around the tyres and the tea tray area. so maybe copying the thing wouldn't work for them or doesn't worth wasting money and time as they shifted their development attention to '17 car.ringo wrote:I'm surprised that no one has copied the multi element barge boards on the merc as yet.
Aero is not the same as Lego blocks: you can't just slap on a random device and assume it will work in an area where even a change of a few milimetres can complete change the whole aero structure at the front.ringo wrote:It will work. The front wings all do the same general thing. The flow control is not that specific; and all the teams want the air in the same general places. Some wings do the job better than others, but they all have the same function and target the same areas.
I'm not convinced it's a very powerful change.ringo wrote:I'm surprised that no one has copied the multi element barge boards on the merc as yet.
Mods please move this post to the STR 11 thread.ClarkBT11 wrote:https://imageshack.com/i/pl7cuTW6j
I have had multiple discussions on this forum over the years, and yes it is like lego blocks.turbof1 wrote:Aero is not the same as Lego blocks: you can't just slap on a random device and assume it will work in an area where even a change of a few milimetres can complete change the whole aero structure at the front.ringo wrote:It will work. The front wings all do the same general thing. The flow control is not that specific; and all the teams want the air in the same general places. Some wings do the job better than others, but they all have the same function and target the same areas.
And the flow is specific. Highly, highly specific. What you are saying is comparable to bathing yourself in beer. Washing yourself with fluids, same basic principle right?
Assuming you're right, the only reason for them not to copy that innovation straight away is because they don't want the extra performance. Even if their aero department was incredibly incompetent, they'd just need to cut some slots into their bargeboard/floor and voilá! They have a faster car.ringo wrote:
I have had multiple discussions on this ... go blocks.
You will see a change. What makes the effectiveness of the change is that you refine the design. Each year i say something should be copied, it's met with protest, and then sure enough teams copy each other and get the results they were looking for.
Aero is sensitive yes indeed, however you can place a general shape in a specific area, for example a batwing, and see an improvement as the formula1 cars all do the same thing aerodynamically. You then fine tune that change to suit your car.
Too many examples to list; S duct, Front wing tunnels, covered driveshafts, monkey seats, bat wings, side pod inlet winglets and many more. Soon it will be multi element bargeboards and hair comb floors, or whatever you call it at the front of the merc floor.
But the batwing is not the same for Red Bull and Mercedes. Far from it infact. Red Bull for instance uses a lift-inducing winglet above the splitter, while Mercedes uses a more neutral winglet a bit higher up.ringo wrote: Aero is sensitive yes indeed, however you can place a general shape in a specific area, for example a batwing, and see an improvement as the formula1 cars all do the same thing aerodynamically. You then fine tune that change to suit your car.
I don't find it so nice.lio007 wrote:Nice analysis on the RB12:
http://www.motorsport.com/f1/news/tech- ... 06747/?s=1
