Renault Motor - Audible external wastegate sound?
F1SC
F1SC
Hi everyone,
I have noticed that the Renault powered cars make an amazing noise as they come off the corners on part throttle and then hit full throttle. I didn't hear this in person at any GP's last season, is this the noise of the external wastegate opening being amplified by the two "screamer" exhaust pipes?
I also haven't noticed the Ferrari, Honda or Mercedes doing this?
The sound is evident below in the first clip, just as the car goes full throttle - sounds fantastic!
NL_Fer
NL_Fer
82
Re: Renault Motor - Audible external wastegate sound?
I believe the strategy is indeed to open the wastegate just after the Turbo has spooled up and run it of the MGU-H for s short moment. It would be the most usefull for using the burst of extra power.
So i asume you can hear it at the beginning of the straights.
DiogoBrand
74
Makes me wonder: with unlimited fuel these power units might even start to sound good.
Jolle
Jolle
133
DiogoBrand wrote:Makes me wonder: with unlimited fuel these power units might even start to sound good.
With unlimited fuel comes unlimited power. Sounds like fun, but the racing is awful.
Awful? did you mean to say fun? because with unlimited power comes unlimited mistakes!
mcjamweasel
Hearing these cars on track this waste gate noise is very noticeable. I was watching the Silverstone test from Vale, and the RB and Renaults were both blowing the waste gate between the left/right. It was also audible on the Mercedes, but nowhere near as loud. I didn't hear any on the Ferrari or Honda.
The Renault also has quite a bit of overrun backfire/burble that the other engines don't have.
Cold Fussion
Cold Fussion
93
On the onboards for the Manor's from last year you could make out the waste gate noises quite clearly.
OO7
OO7
171
The fuel flow restriction would prevent "unlimited power".
Muulka
Muulka
Gone
F1SC
F1SC
I attended the Singapore GP and the Honda sounded amazing in real life. I also noticed it has an audible external wastegate sound on full throttle, found a clip from Monza that shows it pretty well:
https://youtu.be/9Inde7QL_1k?t=92
ojlopez
ojlopez
I know this is not related to the topic, but at about 2:18 it is interesting to see how the Merc's rear suspension behaves on that corner compared to the others.
