1990 Penkse Chevrolet:
kNt wrote:As far as I regard the rules concerning brakeducts (see below), I think they don't limit Teams on introducing a limited size wheelcover. I painted a little side view on how I think the rules restrict Bodywork in this area and in blue a "wheelcover" as I would expect it. What do you think of it?
11.4 Air ducts :
Air ducts around the front and rear brakes will be considered part of the braking system and shall not
protrude beyond :
- a plane parallel to the ground situated at a distance of 160mm above the horizontal centre line of the
wheel ;
- a plane parallel to the ground situated at a distance of 160mm below the horizontal centre line of the
wheel ;
- a vertical plane parallel to the inner face of the wheel rim and displaced from it by 120mm toward the
centre line of the car.
Furthermore, when viewed from the side the ducts must not protrude forwards beyond the periphery of the
tyre or backwards beyond the wheel rim.
All measurements will be made with the wheel held in a vertical position.
I was under the impression that those elements on rallycars are made to keep dirt outside, preventing it from clogging up the brakes? I recall cases of amateurs who had their brakes fail when stones got stuck in between the calipers - even in saloon races.Ciro Pabón wrote:Lancia Delta S4
The way IkNt wrote:I posted this in a seperate thread but apparently this one deals with the same thing.
The periphery of the wheel as I understand it is the front face of the wheel, so a complete cover of the wheels is not possible, but a little gap around the front should be sufficient.
PNSD wrote:*cough cough*
http://img.photobucket.com/albums/v452/ ... corner.jpg
edit - after more looking around, im guessing these move. but still how come f1 never then looked at the idea ???
http://automobile.2405.com/automobile_g ... B_2405.jpg
also ive seen other group c racers with wheel covers, but these were good pics
I think someone at McLaren has been checking out your idea...kNt wrote:I posted this in a seperate thread but apparently this one deals with the same thing.
The way I read the rules, such a Wheel cover around the wheel should be legal:
From my seperate thread:kNt wrote:As far as I regard the rules concerning brakeducts (see below), I think they don't limit Teams on introducing a limited size wheelcover. I painted a little side view on how I think the rules restrict Bodywork in this area and in blue a "wheelcover" as I would expect it. What do you think of it?
11.4 Air ducts :
protrude beyond :
wheel ;
wheel ;
