Frank_
Frank_
Re: Mercedes Power Unit
i agree with the det theory personally, i detted 1 piston once and this its what its bigend sounded like
https://www.youtube.com/watch?v=Mryvypj6Y4s
Det would be easy for them to see on a teardown though.
Frank_ wrote:i agree with the det theory personally, i detted 1 piston once and this its what its bigend sounded like
http://i67.tinypic.com/w96z5j.jpg
I have a friend with the same engine and he had the same problem!
wuzak wrote:Ted and Ant showed the "big end" on the TV for Sky F1.
They showed and talked about a needle roller bearing. Really? I'm not buying it.
Yup they are fools. The roller bearings would prevent the rod knock i think. At least paddy would not use that term if it was roller bearings.
PhillipM wrote:Det would be easy for them to see on a teardown though.
If your engine is designed to run with(IOW tolerate) a certain amount of detonation you'd never know.
It'd show on the ionisation trace in the logging.
Brian Coat
Brian Coat
On the subject of speculation.
Lawrence Butcher speculates in RET this month's that Mercedes is using stratified charge SACI combustion.
NL_Fer
NL_Fer
82
I don't think Mercedes is using very exotic technology in their engine. Seeing how close Redbull is and how far down the other Merc teams are, the difference between engines is not that big anymore.
Because Mercedes is keeping with the same proven concept for at least 5 years now, they exactly know how far they push the engine without breaking and which mode can be run for how many laps. They is they only advantage they have left.
GoranF1
GoranF1
149
240
He isn't really more credible than any of us. He seems to be a casual fan who keeps away from the sport.
Juzh
161
ringo wrote:He isn't really more credible than any of us. He seems to be a casual fan who keeps away from the sport.
Funny how Verstappen mentioned the same 50 bhp.
Facts Only
Facts Only
188
http://cdn.f1i.com/wp-content/uploads/2 ... a_5_FR.jpg
Interesting nugget of info there, the MGUK is "PH1.0" or Phase 1.0. Phase 1.0 will be the very first iteration of the 2016 design and shows that Merc' have not needed to make any changes to that design since (likely) late 2015, not even after initial dyno testing or winter track testing.
Thats a pretty amazing example of "right first time", I know Merc have had their reliability issues this year but that still a sign of how good the design team are. I'd love to see what Phase the MGUH is on, at a guess probably something like PH2.5 after the issues they had in the early season.
hurril
hurril
I wonder what that grey part is that, in the picture, is right above the exhause manifold. It seems to sit right in front of the turbine. Is that the MGU-h, positioned vertically?
Facts Only
Facts Only
188
what grey bit? Either way its defintiley not a vertically mounted MGUH
If the Renault is the next best if that is what Keke is saying.
