Bottas has indeed broken an 11 year old top speed record in F1 during a race weekend
Juzh
161
According to THIS article, Bottas has actually beaten the maximum ever recorded speed during a race weekend this sunday in mexico, with a top speed of 372.54 kmh.
FIA speedtrap mexico 2016:
http://www.fia.com/file/49841/download?token=pw7Swwc6
Previous record was held by Raikkonen from the 2005 monza GP at 370.1 kmh.
Speed chart from that race:
As explained in the article, Montoya's infamous 372.6 kmh was not set during a race weekend, but rather at a testing session one month prior to the race. Testing does not require cars to be 100% legal and could also be used to try unusual setups not most likely to be applied to the race itself (honda's 400 kmh run in the desert as an extreme example).
So yeah, williams now hold a double record (massa also beat 2005's record) for the fastest ever top speed achieved by an F1 car in an official session :!:
edit.
To further cement this fact: https://twitter.com/OskariSaari/status/ ... 1087767552
Andres125sx
Re: Bottas has indeed broken an 11 year old top speed record in F1 during a race weekend
Speed traps are not reliable as they´re not exactly half meter before the braking point wich is the real top speed. Only telemetry can tell you the real topspeed
During the race Pedro De La Rosa explained at the spanish TV he did at Monza 05 (free practice ) 374km/h. Actually he said he still has that lap at home, I guess he meant the telemetry
But since it was not the race, it´s not official, so Montoya record that same weekend (Yes, that weekend, not sure where they got it was on a testing session, but that´s BS) still apply as the oficial record at 372.6 km/h in Monza 05 (race). If I´m forced to choose who´s more reliable, DeLaRosa who drove that car and participated in that GP, or the writer of that article looking at speedtraps, I obviously have no doubts at all :wink:
Even F1 official website say it´s Montoya´s 372 the oficial record
https://www.formula1.com/en/latest/feat ... -2016.html
Andres125sx
I must add Mexico top speeds are impressive tough, it shows how thin is air at that altitude when they are so close to speed records while using Monaco wings :shock:
tomazy
tomazy
223
Andres125sx wrote:Speed traps are not reliable as they´re not exactly half meter before the braking point wich is the real top speed. Only telemetry can tell you the real topspeed
Didn't Williams say that Bottas hit 378 hm/h according to telemetry in Baku qualifying I think? Does qualifying count as an official seson?
https://twitter.com/WilliamsRacing/stat ... 4693046272
Juzh
161
By that logic we don't really know how fast bottas got when he recorded 372.5. But since that information is next to impossible to obtain, the only logical thing is to take the official numbers, which is the only constant troughout the years.
I love how you call out BS on someone who has done some research on the topic whereas it seems you've done none. All you've got is some hearsay rumours. It doesn't even look like you've read the article I've linked, which posts a number of sites reporting montoya's 372.6 as being set in testing.
Would not be the first time official F1.com spreads wrong information. I particularly liked this bit from this article:
https://www.formula1.com/en/latest/feat ... prost.html
"faster than Kimi Raikkonen's Monza speed trap record from 2005, but just 0.1km/h shy of what Juan Pablo Montoya was clocked at at a different part of the circuit in the same race."
As if there's any other point on the circuit other than at the end of start/finish straight montoya could have set that speed.
Thanks for the downvote.
Andres125sx
Juzh wrote:I love how you call out BS on someone who has done some research on the topic whereas it seems you've done none. All you've got is some hearsay rumours.
Sorry but first hand experience from a driver who drove that same car that same weekend (so he obviously had access to telemetry) is far from a rumour :wink:
About the downvote, if you would have no votes I had not downvoted, but I felt inaccurate info does not deserve 2 upvotes. Not your fault obviously
hollus
Bottas' 378 was set in practice in Baku. It is in the article in formula1.com. So, a mis-setting of the wings, really.
I think we all agree that the records should at least be set in quali or the race?
TANSTAAFL
Juzh
161
hollus wrote:Bottas' 378 was set in practice in Baku. It is in the article in formula1.com. So, a mis-setting of the wings, really.
Bottas' "378" was in Q3.
hollus
Cars have gone beyond the record speed already this year - albeit only in practice and only at an unfamiliar circuit where the cars weren’t fully dialled in via simulation in the way that would usually be the case. “I think we hit 378km/h in Azerbaijan,” says Rob Smedley, Williams Head of Performance Engineering. “Would we go as quick in a race? No way. More wing!”
At least that is what it says in the piece in formula1.com linked further up.
It strongly suggests a messed up setup beyond what could happen in Q3, but I have no hard info to back it up.
TANSTAAFL
Juzh
161
It's just formula1.com being formula1.com. It's pretty silly how many things they've gotten wrong in just the past few months.
It was 100% in Q3 and onboard timing max speed recorded was 370.
https://streamable.com/5ms9
And we're back to twitter being the only source for 378. It has been discussed already why it's a moot point even if it's actually true (unlikely).
Fulcrum
Fulcrum
Probably impossible to answer, but how fast is this when applying a standard atmosphere? I.e. sea-level equivalent conditions.
hollus
Air density is abou 8% less in Mexico which very roughly translates to 8% less drag. So cut about 30 km\h from it for normal air density.
TANSTAAFL
