Sauber C36 Ferrari
jagunx51
185
Re: Sauber C36 Ferrari
Tech update: Sauber's unique monkey seat solution
https://www.motorsport.com/f1/news/tech ... on-881323/
roadie
39
The bargeboards seem to be situated very far forward of the sidepods too. I know there are a number of cars on which this feature is the case, but are the Sauber's placed the furthest forward?
The sauber exhaust pipe is very close to the wing.
I really don't know why they're doing the monkey seat like that, it should always be less efficient than the usual ones blowing the suction side, unless it lets them run the exhaust higher or something like that? :wtf:
hurril
hurril
Man the new Sauber really does look good!
jagunx51
185
PhillipM wrote:I really don't know why they're doing the monkey seat like that, it should always be less efficient than the usual ones blowing the suction side, unless it lets them run the exhaust higher or something like that? :wtf:
I think they want to separate the hot gas away from the diffuser, looks like they try to maximize the ground effect ....... I think it is only a temporary part, because there is a temperature sticker on the M-seat, perhaps they are aware that blowing the gas on the upper surface could damage the M-seat
And the wastegate pipes are in their 'normal' position, the gas flows on the suction side of the M-seat ...... it is possible that they might try to move them close to the main pipe, we'll see
michl420
michl420
It Looks like a temporary solution, but when not than maybe they are trying to blow the underside of the rear wing. Also i do not know if the exhaust Position is legal.
Godius
186
ScrewCaptain27
577
Sauber C36 Ferrari
More pics from AMuS:
- Serj Tankian
ScrewCaptain27
577
New flow conditioners behind the FW cascades. Don't remember seeing something like that before.
- Serj Tankian
ScrewCaptain27
577
Sauber C36 Ferrari
- Serj Tankian
sauberfan
sauberfan
19
ScrewCaptain27 wrote:
22 Mar 2017, 17:12
I checked it as well and it seems to be a modified FW!
They Changed a bit more than just the FW cascades =D>
Drica
sauberfan wrote:
22 Mar 2017, 17:19
22 Mar 2017, 17:12
https://pbs.twimg.com/media/C7g_6HbXkAEaMnP.jpg:large
The tunnel hasnt changed, youre pointing at two different parts of it
oetger
AMUS
