ENGINE TUNER
ENGINE TUNER
25
Re: Honda Power Unit
Sasha wrote:
09 Apr 2017, 17:37
Maybe Spain because it will be on the second PU used for the season.
If they have a better PU ready they can introduce it now and just relegate this first PU to practice duty only.
63l8qrrfy6
63l8qrrfy6
368
Would it not be better for honda to withhold upgrades until they have a competitive package ?
If they just bring in a new engine with minor upgrades they are essentially stuck with it and the current one for half of the races.. And it's not like they are extraordinarily reliable either - they can't realistically hope for more than 5 races on a single engine.
ENGINE TUNER
ENGINE TUNER
25
etusch wrote:
09 Apr 2017, 10:01
This drive shaft problem may be caused by engine sudden tork load during alo's re overtake affort to sainz.
Or when ALO went off track and had the left rear on the astroturf and the right rear on the tarmac and slammed the accelerator. Those type of unequal loadings kill driveline components.
ENGINE TUNER
ENGINE TUNER
25
Mudflap wrote:
09 Apr 2017, 18:36
Define "competitive package" please. ALO is just outside of Q3, so a decent jump in power maybe 50hp could possibly get them into 11th or maybe Q3 and the lower fuel they would have to carry could allow them to get sorely needed points. Regardless they have a lot of work to do.
HPD
198
ENGINE TUNER wrote:
09 Apr 2017, 18:38
etusch wrote:
09 Apr 2017, 10:01
Alonso vs Sainz
https://www.youtube.com/watch?v=jfxNOODUg9I
ENGINE TUNER
ENGINE TUNER
25
HPD wrote:
09 Apr 2017, 19:14
ENGINE TUNER wrote:
09 Apr 2017, 18:38
etusch wrote:
09 Apr 2017, 10:01
Alonso vs Sainz
yes, right then, did he not stop a lap or two later?
63l8qrrfy6
63l8qrrfy6
368
ENGINE TUNER wrote:
09 Apr 2017, 18:41
Mudflap wrote:
09 Apr 2017, 18:36
By competitive I mean on par with Renault both power and reliability wise.
It looks as though they have a couple issues to sort out - some unspecified head/valve problems as well as the driveline vibration (after today I am not convinced it's honda's fault).
Anyway whatever their problems really are I am hoping that they are addressed properly with the next iteration, allowing honda to catch up throughout the second half of the season. Stacking band aids on top of band aids for minor gains will just make it worse - it would be just another house of cards to collapse, prompting another redesign the following season.
toraabe
toraabe
With more power they have to change the final drive. I am sure because the current one is way too short if they want to be able to be faster
hollus
It is only shorter to the tune of some 5km/h, though.
https://www.f1technical.net/forum/viewt ... 79#p689979
If they don't expect to match the power of the Mercedes and the Ferrari, they might be OK. No reason not to use the gear ratio change allowed this season, though.
¡Puxa Sporting!
McMrocks
McMrocks
32
Isnt it possible that Alonsos re-overtake was due to the driveshaft failure and losing MGU-K breaking power?
etusch
131
toraabe wrote:
09 Apr 2017, 19:51
İf they are shifting earlier than planned rpm because of vibrations and in the same time if there is lack of power, those both is cause of low max speed. Not last drive.
When they achieve to have expected power and reach to rpms they want, I am sure 30 km is not need so much rpm. I know there are forum members can calculate this, I am just giving example, 30 km speed does not need 300 rpm or may be just about 300 rpm. İf they have 12.100 now and without vibration problem if they have 12.500 rpm they could have highest max speed.
gruntguru
gruntguru
579
Frank_ wrote:
07 Apr 2017, 17:26
the chamber will be flushed during the (tdc) valve overlap period wont it ? with some help from a shaped piston crown
No. The holes are quite small relative t the pre-chamber volume. The pre-chamber empties down to exhaust pressure during the exhaust stroke and fills with fresh charge during the compression stroke. The retained exhaust gas is less than 10% of the fresh charge squeezed in.
FW17
184
Can the inlet valve open and close the side of the pre chamber with the fuel injection actually directed into the inlet manifold?
hollus
etusch wrote:
09 Apr 2017, 22:55
toraabe wrote:
09 Apr 2017, 19:51
The problem is the opposite, Etusch. They are always running too many revs, shifting later than normal. They basically stay between 11000 and 12600 most of the time, while optimum power would be something like 10400-12000. The (resonance?) problems appear around 10500rpm, apparently.
So, if and when they fix it and get the power back, as 8th gear is now, to reach 330 km/h they need to be at 12000 rpm, but by that point, they have lost significant power.
Note: 30km/h is approximately 1200 rpm.
¡Puxa Sporting!
etusch
131
hollus wrote:
10 Apr 2017, 08:07
etusch wrote:
09 Apr 2017, 22:55
toraabe wrote:
09 Apr 2017, 19:51
Thank you for correction
