Effects of Car in Front of Car Close Behind
EvilPhil II
EvilPhil II
Everyone appreciates that when a car is close behind another, that the following car loses down force and can enjoy the benefit of a tow.
I'm wondering if when a following car is close to another car in front if there are any likely effects on the car in front? e.g. can it effect the car in fronts rear wing efficiency by disrupting the airflow off the wing?
CSH17
CSH17
Re: Effects of Car in Front of Car Close Behind
In NASCAR the effect of the following car is used in pack drafting as the car behind reduces the impact of the low pressure region behind the leading car
You know that's actually a good question, and on the face of it, it does make sense. It's been shown that rear aero affects the front, so why wouldn't a car disrupting rear aero not affect the front end of the leading car? Possibly why Riccardo, and Raikkonen were slow when they were in the middle of the train. And why Verstappen started struggling when he was in a HAAS and Riccardo train.
Maybe pushing and getting close to the lead car affects it's downforce enough that the tires start sliding around a bit more, so it loses some pace and increases tire wear. Although the trailing car suffers a little more, maybe it's still possible to set up an undercut by closely trailing the leading car as much as possible.
hollus
In Nascar, the car behind can be 20 cm behind, or even 0 cm behind.
How often and for how long is it that the car behind is less than 2 car lengths behind in F1?
The effect, is there is any, will be negligible, IMHO.
Rivals, not enemies.
marvin78
marvin78
Nascar and F1 are really similar.
Nascar doesn't depend so heavily on aero as F1 does. A NASCAR is essentially a rolling brick by comparison. F1 has flow structures, tiny aero surfaces, and complex interactions from the front wing to the diffuser.
toraabe
toraabe
Go back to groundeffect.
bhall II
bhall II
473
toraabe wrote:
10 Apr 2017, 17:10
The vast, overwhelming majority of downforce generated by F1 cars is the result of ground effect. That's not the answer.
Anyway, between two cars running in tandem, the leading car suffers little disturbance. If anything, it might even experience a slight downforce gain...
via SimScale
bhall II wrote:
10 Apr 2017, 18:23
toraabe wrote:
10 Apr 2017, 17:10
It's his only answer. He brings it up in thread after thread.
http://i.imgur.com/Cggn1FJ.jpg
via SimScale
It's possible that the leading car gains from the front wing of the trailing car helping to drive the leading car's diffuser. I'd guess it would need to be very close for this to occur but in your image there is a suggestion that it happens.
EvilPhil II
EvilPhil II
Would this create understeer for the leading car?
bhall II
bhall II
473
EvilPhil II wrote:
10 Apr 2017, 23:31
In general, increasing the efficiency of the diffuser also tends to increase the efficiency of components upstream.
bhall II wrote:
11 Apr 2017, 01:05
EvilPhil II wrote:
10 Apr 2017, 23:31
Assuming that 2017 cars have the same wake profile as the previous generation cars, and the leading car's diffuser would work better with a new car in tow.
toraabe
toraabe
Just_a_fan wrote:
10 Apr 2017, 18:52
bhall II wrote:
10 Apr 2017, 18:23
toraabe wrote:
10 Apr 2017, 17:10
=D>
wuzak
wuzak
446
godlameroso wrote:
10 Apr 2017, 13:55
Verstappen was never in a "Haas and Ricciardo train".
Verstappen was never close enough to get a tow, though he may have felt some effects. But the biggest effect he was having was that his tyres were old and shot.
RicME85
52
wuzak wrote:
11 Apr 2017, 10:37
godlameroso wrote:
10 Apr 2017, 13:55
I think thats the key thing here. He was so far behind the Haas that it must of been tyres that were the issue as Ricciardo was right up behind Max, a lot closer than Max was to the car in front. Now with tyres lasting longer you cant jump in the pits if you are in that situation and claw the places back as other cars slow down due to the age of their tyres in comparison which then creates these 'faux trains'
