FIA ruining F1 in the name of safety
zac510
22
Re: FIA ruining F1 in the name of safety
It's my observation that it's mostly the bottom half of the grid go off the track. If there were any entertainment in a driver getting stuck in the gravel, it will instead be immediately written off as poor driving by a driver in a low grid position. The top drivers just don't go off the circuit nearly as often so this fantasy that top drivers will get punished for mistakes will rarely come alive.
Giblet
The current level of safety in the sport is because of people in the sport constantly looking to make it safer.
Either you think no safety regs ever should have been installed, or you think that for some reason, current F1 is exactly as safe as it needs to be.
After Jules accident, should the FIA have NOT come up with the VSC?
cplchanb
Giblet wrote:
21 Apr 2017, 12:32
Imo the idea of vsc is good
But the implementation and execution if it needs to be improved. It is being used way too liberally the last couple of years where it has decided races and championships for incidents where it wasn't really necessary to use it. Do they even use double waved yellows anymore or has Fia become so distrustful of a drivers ability to adhere to the flag rules that they throw vsc every time there's a car off "near" a corner....
The_table
What is the problem with vsc again? the fact that they "waste" laps? maybe they should freeze the lap count while under vsc?
(The problem is that they would probably end up in trouble for fuel :/ ... )
cplchanb
The_table wrote:
21 Apr 2017, 18:23
IMO theres no need to slow down the rest of the lap... just impose the VSC on the sector or 1 flag zone before and after...They have the tech to track speeds
Jolle
132
With this the horrible F4 accident in mind and the motorbike deaths in the last few years (drivers getting run over), maybe the next level of safety is a more active one. So far the FIA only worked on building more structures, better chassis, more equipment around the drivers heads and a few procedures (like the VSC). What if, trough the ECU there is a max speed differential on certain parts of the track?
If a driver slows down a lot, it's picked up by GPS and other drivers are first warned (a few corners ahead, a racetrack is pretty predictable) and an automatic speedlimit on that section (for instance, "slow car + 50km/h)
This system could also be used to "punish" driving outside the lines, on the tarmac where once gravel traps were.
with taking an active role in not crashing (to hard), F1 on a road safety level gets more relevant as well.
The_table
I guess the back of a F4 car is a very weird structure to crash into compared to a concrete block (is that still how nosecones are tested?) and in the footage you could see that the car was not flat on the ground when the other car crashed into it, it got lifted up, it looked like the other car went half into it and half underneath it, splitting the nosecone of the car in half horizontally. (The top half shattering and the bottom half not, or at least not as intended.)
cplchanb
Jolle wrote:
21 Apr 2017, 19:08
I don't think it would work well....the sudden deceleration from 200km to 50 will for sure damage the drivers neck. Even if it was possible I don't think the system would be able to react in time to this type of situation. At that point there wouldn't be much point in using this system since by then there would be enough time in 99% of the cases to see and react to the situation.
cplchanb
The_table wrote:
21 Apr 2017, 19:50
I think in this situation the only way of mitigating damage and injury for a head on collision is to improve the crash structure. The driver wasn't particularly driving at insane speeds but the nose was just not designed to sustain a full force impact like that. Unfortunately though that would mean a spike in costs which will hinder young amateur driver careers
cplchanb
The_table wrote:
21 Apr 2017, 19:50
strad
117
You do realize the ultimate conclusion of constantly pushing for more and more safety is in the end driverless cars with no spectators allowed anywhere near the track.
Sir Stirling Moss
Jolle
132
strad wrote:
21 Apr 2017, 22:35
Maybe they should hook up all the simulators and run it throug a big Renderman stack so it looks real, feels real but all CGI :P
Andres125sx
strad wrote:
21 Apr 2017, 22:35
That would provide some spectacular racing cars. Imagine if those could corner at 15G safely :twisted:
The_table
strad wrote:
21 Apr 2017, 22:35
I bet the ultimate conclusion of constantly pushing for faster and faster cars is exactly the same... :mrgreen:
(Weight reduction, comfort of your driver,etc)
strad
117
It would be boring as hell.
Sir Stirling Moss
