Rear wheel steering for yaw correction
Greg Locock
233
Re: Rear wheel steering for yaw correction
roon - We call it crabbing. Imagine a body in plan view with two steerable axles. So long as both axles steer by the same amount you can have the body sat at any yaw angle to the direction of travel, whilst still tracking straight. On a Hunter alignment rig I think the total rear axle steer is called the thrust angle, a hangover from live rear axles.
The 2002 Mazda RX-7 had "rear steer" which was really just compliance steer in the rear axle, it worked well on the stock car, but usually this is changed to full spherical bushings when you tune the car for speed.
Greg Locock
233
Every car ever built has had compliance steer (once in a while somebody may have tuned it out for one particular lateral load and tire). The body is typically not a great deal stiffer than a hard rubber bush, and I can point you at a rubber bush that is as stiff radially as a tie rod spherical joint, so that's about 3 times stiffer than the body, and 7 times stiffer than a tall spindle. (Ballparky numbers 5 kN/mm, 2-8 kN/mm 14 kN/mm 14 kN/mm 2-5 kN/mm)
Bushings and SBJs and suspension arms behave like springs in series 1/k_overall=sigma 1/k(1...n). You may not be amazed to hear that the stiffness of the wheels and the wheelbearings (to a much smaller extent) is also significant.
What's funny is that all these bignum stiffnesses are being used to control a floppy rubber thing with a stiffness of 250 N/mm or thereabouts, yet their effect is quite measurable both on the K&C rig and the road and subjectively.
I never thought about the wheel bearings, good call!
