[MVRC] Mantium Virtual Racecar Challenge 2017
Alonso Fan
Re: [MVRC] Mantium Virtual Racecar Challenge 2017
CAEdevice wrote:
10 Aug 2017, 19:16
Thanks LDVH, may Chris summarize the rule update?
I am getting crazy with the first race model: I only changed two small things (minor legality issues) and now it stops after meshing (successfully) when solving the first iteration.
Tommorw I will try with MFlow v2017.7.
Same issue here
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
LVDH
52
2017.7 could indeed help. Please try it and let the others know what happened.
CAEdevice
51
LVDH wrote:
10 Aug 2017, 21:49
I sent you the logs: I can only find that the solver crashed during first iteration. The mesh seems to have been completed.
cdsavage
cdsavage
19
CAEdevice wrote:
10 Aug 2017, 19:16
The changes should all be highlighted in yellow. There are only two things worth mentioning:
  • We are adding the once-per-season deadline waiver. You can extend the deadline by two days but you must ask to do it before the deadline passes.
  • The wording was changed in K1.4 to make it clear that the left and right parts for special_bc, monitoring_surfaces and porous_media must be submitted as separate STLs. This was a common problem in round 1.
rjsa
rjsa
51
About the crashes, I had an odd one - I can't remember in exactly which phase - that was caused by a rogue binary STL.
CAEdevice
51
Update: with MFlow 2017.7 the "first iteration" has been solved (the first test, with a geometry that failed with 2017.6 has been successful). Thanks!
Alonso Fan
CAEdevice wrote:
11 Aug 2017, 10:13
Oooh this is good news. I will try a simulation today and confirm if the issue is also fixed on my side
SHR Modding
Youtube
Twitter
Discord
rjsa
rjsa
51
LVDH wrote:
10 Aug 2017, 19:09
Hi guys,
sorry I was so quiet lately. I was simply working like crazy. I have made some small improvements to the software. You can now download version 2017.7. It seems to solve some issues you guys had with solver stability. I say "seems" because I did not have very much time to check it extensively. Maybe some people can test it and esp. rsja can possibly confirm that his simulations are now a bit more stable, we should go for using this version for the next race which seems to be next week already.
Also there is an update to the rule book. I did not have a look yet but also there the changes should be minimal.
I'm re-running my last interaction on it.
This you get to look into the windows/linux report issue?
Alonso Fan
Alonso Fan wrote:
11 Aug 2017, 11:03
CAEdevice wrote:
11 Aug 2017, 10:13
issue seems to be fixed. simulation is currently on iteration 540 or so
Although issues with my car don't seem to be fixed at all...
SHR Modding
Youtube
Twitter
Discord
CAEdevice
51
Completed first run: dr and df changed slightly, but cooling flow is now much lower.
The post processing issue still happens (I get only a few images).
rjsa
rjsa
51
I'm still running it but the intake flow that I had fixed went craaaaaaazy.
CAEdevice
51
rjsa wrote:
11 Aug 2017, 16:59
Same for me now... luckily it oscillates (a lot) into a valid range.
rjsa
rjsa
51
CAEdevice wrote:
11 Aug 2017, 17:11
rjsa wrote:
11 Aug 2017, 16:59
Yep, for me anything between -1 and 4. By the looks it'll average around 2
By the way, as the new guy I'm a bit lost with names. My name is Ricardo. I've caught a few names:
-Matteo
-LVDH is André, right?
-Chris
Who else?
rjsa
rjsa
51
Yup, intake really bad, but positive. HX flow wrnt below 1.5 and dropping solidly by the end of the run.
I'd like to know if it's going to be used as I have two very distinct development paths ahead of me.
CAEdevice
51
I have a reduced cooling flow too (-10%). No problem for this (high df) race, but I hope the solver remain the same in the last three races (efficiency).
