Proximity Warning
Shrieker
Re: Proximity Warning
wesley123 wrote:
21 Sep 2017, 01:11
Okay, so how is that system going to give a warning like that if it is only a proximity sensor?
In all fairness, I did not use the word sensor in any of my posts. I used the term transponder. Commercial aircraft for example have transponders working in conjunction with one another to avoid mid air collisions, called the TCAS. It not only warns the pilots of each plane that they are on a collision course, but also instructs one of the planes to ascend, and the other to descend. This has precedent over anything else, including the ground based instructions. That shows how much faith and emphasis the aviation industry places onto this system. I thought just watching the video i linked to for 5 seconds would've sufficed in this regard :oops:
wesley123 wrote:
21 Sep 2017, 01:11
For example; "For the car on the left, how does he get his feedback to know there is another car next to the car he is close to on the right?" has not been answered in any of your posts beforehand, and neither were the other points for that matter.
Well... Just going by iracing, I would say the software required is already done and well understood. The spotter in that game(sim, or whatever people want to call it) isn't scripted. It reads out warnings to the racers based on 3 dimensional positioning. So it's something already done before, software-wise.
So coupled with the above, everything is in place technically speaking. What's missing is the will to do it.
But if you would have me elaborate verbally ( not that I think you need it), here it goes:
The transponders on both sides of the car can be interlinked. If there's, -say- two cars on either side of your car, your transponders will be relaying the information to those cars that yours is the car in the middle, hence a three wide.
-Atatürk
DiogoBrand
74
Incidents happen: "How can we prevent accidents from happening"
Incidents do not happen: "F1 is predictable and boring, we need to introduce some excitement"
Why prevent the only thing that can make Marina Bay interesting from happening?
TAG
Park Assist.
माकडाच्या हाती कोलीत
Shrieker
DiogoBrand wrote:
21 Sep 2017, 03:41
Would you still have said that if some 13-14 cars had been wiped out in the first corner last weekend, and we got a race like Indy 2005 ? Personally I did not like what happened to Max/Kimi/Vet, it made for an extremely dull race. And the ones who created the problem (Vet and Kimi) possibly to probably never had an idea that there was another car on the far side.
-Atatürk
TAG
Shrieker wrote:
21 Sep 2017, 03:50
This is the real rub for you.
Spacial awareness is part of racing, without even getting into the technical aspects of implementation, would they have been able to react to a warning in a timely fashion given that they went from racing to crashing within a second? Let the drivers that have that better spacial awareness keep that racing advantage.
rscsr
51
They could also just use spotters, at least for the starting sequence.
krisfx
krisfx
This has been a non-issue for a long time. I'm not sure why it's all of a sudden an issue, unless you're a die hard Vet/Ves/Rai fan
marmer
marmer
Surly it would better to have a sensor in all for wheels linked to the edge of the track for track limit breaches
Jolle
Jolle
133
Shrieker wrote:
21 Sep 2017, 03:16
Jolle,
Agree pretty much everything in your post, except this bit:
Jolle wrote:
21 Sep 2017, 01:17
Spacial awareness is one of the things that makes a fast driver a great racer.
Vettel couldn't have seen Kimi on the far left. It was just physically not possible. There was Maxstappen's car in the middle blocking the view. Same goes for Kimi. You're gonna get the same problem whenever there's a three wide. For side by side racing involving only 2 cars I get it, it should be down to the drivers, and drivers alone. However, every now and then you'll get a situation where it's impossible to tell who is where. Like last weekend.
Vettel took a risk by cutting the starting straight so sharply after a not terrific start (in the rain!). He should have known better and this will probably cost him his chance on the world title. If you take a risk, it might nog work out. Look back to the start, everybody is careful, driving straight when there are other cars around (spacial awareness!!!) and there is one guy cutting across track... that one guy who couldn't afford a DNF....
zac510
zac510
22
This would be great for endurance racing where there are slow GT cars and fast LMP cars overtaking each other regularly.
Shrieker
krisfx wrote:
21 Sep 2017, 07:39
This has been an issue multiple times in the past. If you check my posts, you'll see one occasion where it was horrible. And back then they had spare cars. The race would not take place if it happened today. And no I don't particularly like any of those drivers.
-Atatürk
Phil
66
Shrieker wrote:
21 Sep 2017, 03:29
There was a plane crash, not too many years ago, in Switzerland where the TCAS should have avoided an airplane collision from happening, but didn't, because the plane received conflicting instructions by the air traffic controller, whom the pilot decided to trust and follow. As you say, the TCAS has precedent over anything else, but on this occasion, the pilot clearly didn't follow it.
This brings me to the point that even if F1 cars were equipped with a similar technology (lets assume it to be possible), the faith of the car would still rest in the sanity of the driver. If we look at what happened at Singapore (which I assume prompted this topic in the first place), well, Vettel, it seemed, was going to chop to the left no matter what. Some would refer to this being a bullying tactic: "I am going to chop off your path - if you fail to back out, we will both crash". The whole point of such a maneuver is to force the other car at a disadvantageous position to yield.
I am fairly confident that even if Vettel had the mental awareness or a tool such a system like the TCAS to see Kimi coming up from the inside, he still would have attempted to close the door. His trajectory was too aggressive for that and it was sending a very clear signal: "I am moving to the inside at all costs". In his mind, it was Max's responsibility to back out in time (which he was in the process of doing, if Kimi wasn't there to close the gap to the other side).
I'd also go on to say that the feasibility of such a system like the TCAS for F1 would be an impossibility. Why? Because the system is primitive. It can not know who is in the right or wrong etc. The cars and drivers are also too erratic. At speeds of 200kmh+ you are traveling at 55+ meters per second. Every two tenths, a meter. Sudden direction changes have a huge bearing on where your car will be half a second later on a track that is so narrow that it barely fits 4 cars side-by-side (best case).
Even if we have very simple proximity warning sensors or something; either they'd be so sensitive that they'd already be warning a driver if a car is sufficiently far away, or it only starts warning when it's too late. It just can't work. And why should it? The TCAS (in aerospace) is designed as a system that communicates with the TCAS of another plane, sorting out who is to do what. It just ain't possible in motorsport, not as long as these things happen within split seconds at high speeds on a very narrow track and every millimeter can determine the outcome between hero and fail.
Post Singapore, there was some discussion on the Channel 5 (4?) broadcast with some people from Nascar that perhaps F1 should look into the idea of using spotters for drivers. But what may work on an oval, would probably not work on a normal F1 track and certainly not at the start where everything is rather unpredictable.
F1 is good as it is. The drivers have side-mirrors that give them a reasonable understanding on what is happening around them. Generally, I'd say the car doing a direction change has some responsibility to know if a car is along-side (or partially) and under no circumstances should crowd that car off the track. There are a few exceptions to this rule, namely corner exit because a driver may already be committed to a certain entry/exit speed and his trajectory given by those factors. This makes him more or less a "by-passenger", even in the event that an overtaking driver attempts to put his car in the closing space on corner exit. I'd also explicitly point out that in any circumstance, usually the car behind has a certain responsibility as a result of better coverage. You can't expect the car slightly ahead to have a perfect awareness of what is happening behind him. It's easier for the car behind to see what is happening before putting himself at risk. This however, as mentioned above, does not allow the "leading car" to do any kind of maneuver, especially when doing direction changes.
But apart from that? What more do you want to do? Micro managing every part of the sport will only lead to dull and predictable races.
#Team44 supporter
taperoo2k
taperoo2k
Shrieker wrote:
20 Sep 2017, 21:12
taperoo2k wrote:
20 Sep 2017, 20:43
All you'd end up creating is a very stale start procedure
This is not to prevent drivers from racing... It's to provide them more awareness as to what's happening around them. I thought that much was clear...
It's taking away from an F1 drivers skill set, if you give them what is an electronic aid to help them. Unless of course you want to stick cameras onto F1 cars that then feeds into the steering wheel's LCD screen so they can see whose behind them. I'm a traditionalist when it comes to the start of an F1 Race, no guts no glory. It takes guts to tip toe your way through the chaos rather than flooring it in an attempt to make it to the first corner in the lead. Lewis tip toed his way through the chaos (almost lost his front wing in the process and moved away from Vettel) and ended up in the lead and eventually won the race (helped by Riccardo having to nurse his gearbox to the end, would have been a different kind of race if he'd not had that issue). Of course we'd have all preferred it if Vettel, Kimi and Max had made it through the start. But that's racing, you never really get what you want apart from on rare occasions and those races tend to be the ones that live long in the memory.
Of course the people who should be asked this question would be the drivers themselves.
krisfx
krisfx
Shrieker wrote:
21 Sep 2017, 13:41
krisfx wrote:
21 Sep 2017, 07:39
I'm sure in an ideal world you'd have time to react to a blind spot device, but I'm not sure in the heat of the moment it would even be fast enough. The crash in Singapore was over in seconds...
Shrieker
taperoo2k wrote:
21 Sep 2017, 14:00
But how is a display not a driver aid then ? Coupled with the fact that they'd have to look down to their wheels and not the road ahead. This is a no go imho.
taperoo2k wrote:
21 Sep 2017, 14:00
Agreed.
taperoo2k wrote:
21 Sep 2017, 14:00
Again, agreed. They can test it in iracing if they would like to :) And then decide whether it's worth trying on a real F1 car or not.
-Atatürk
