NathanOlder wrote: ↑22 Sep 2017, 19:28
Phil, after reading your predictions it sounds almost like Vettel is favourite for this title.
What if they are? A few things to ponder...
The fact that after Monza, the gap was merely 3 points in Hamiltons favor, him having won his 6th GP vs Vettels 4 should be quite alarming. Two more wins and only a point advantage of 3 points? This suggests that one driver has been quite a bit more consistent so far this season than the other.
My calculations back this theory up. Again: On average, Vettel finishes in position 2.6 when not winning over Hamilton in position 3.8 when not winning. Here's the numbers sheet I made to illustrate how these numbers were derived:
NOTES:
1.) Column 1: Reality, Column 2: Altered results, Column 3 position & point loss vs the other driver
2.) I did the math with slightly altered results to get a better picture of car/driver performance
3.) those alterations were: Baku: HAM win, VET 2nd, Silverstone: VET 3rd (no tire blowout), Singapore VET win, HAM 4th
4.) I only analysed races where either VET or HAM won. Excluded were Russia and Austria.
5.) Numbers are rounded to one digit
6.) On the premise of these alterations, VET would be leading the WDC by 10 points (wins 5 vs 7).
7.) Apologies about the scale/size. Lazy printscreen off mobile...
8.) And yes, quite evidently... I have no life.
Why is that?
I think there are a few reasons for this:
#1
The Mercedes is a bit on a knife-edge where set-up is concerned. Either it works or it doesn't. This has led to races where one of the Mercedes was fast and the other was not. Or both slow. Or both quick.
#2
Ferrari have been consistently strong, even on tracks where they have been slower than Mercedes, they were easily 2nd fastest. In short: Ferrari has a very good package that works very good on most/all tracks so far.
#3
When the Ferrari is strong, so is RedBull. I think this is due to both having a similar design philosophy (short wheelbase, high rake). The difference being that Ferrari has a better PU.
I think these are possible reasons that lead to the very simple conclusion: When Vettel wins, there's usually another Ferrari or RedBull in 2nd and 3rd with Mercedes behind. Vice-versa, when Mercedes wins, it's usually a Ferrari right behind, if not right behind Hamilton. The statistics so far underline this trend quite nicely. And if this "trend" prevails over the course of the next coming 6 races, Hamilton could find himself needing the "buffer" he has gained over Vettel to secure his 4th WDC.
So I've done the math and as far as permutations go, it looks something like this:
#Vettel is WDC if (assuming Hamilton does the best possible results...)
- he wins all 6 remaining GPs
- he wins 5 out of the next 6 GPs and secures 2nd in the GP he doesn't win (WDC on count of wins)
#Hamilton is WDC if (assuming Vettel does the best possible results...)
- he wins at least 1 GP and finishes at least 2nd in the rest and Vettel has a 3rd place
- he wins at least 2 GPs and finishes at least 3rd in the rest (Hamilton wins by 2 points)
- he wins at least 2 GPs and finishes at least 2nd once, twice 3rd and once in 4th
- he wins at least 2 GPs and finishes at least 2nd twice, once 4th and once 5th
- he wins at least 2 GPs and finishes at least 2nd three times and once 8th
- he wins at least 3 GPs and finishes one time 5th and two times 6th
- he wins at least 3 GPs and has a DNF and a 3rd and 4th place
- he wins at least 3 GPs and has a DNF and a 2nd and a 6th place
- he wins at least 4 GPs (yes, he can have two DNFs then)
Now, I think it's highly unlikely that one or the other will go on a winning streak. As far as remaining races go, I think some of them will be a toss up and some could be Ferrari territory (Brazil, Mexico, Abu Dhabi). In my personal opinion, if Hamilton secures at least 2 wins, it will be crucial for him to finish at least 3rd in the rest. Which, according to my stats is unlikely given he finished on average in position 3.8 when not winning so far, yes, seldom in 2nd behind Vettel. This means he will have to be better than he has been so far this season. If it is achievable will depend on how strong Kimi is and if a RedBull will be ahead of Hamilton. So I'd rather stick to the numbers highlighted in my spreadsheet under the assumption that if Vettel wins a race, there's a higher probability of Hamilton finishing on average in position 3.8 (e.g. more often 4th than 3rd). If this assumption holds true and proves to be correct, he will need to finish statistically higher than Vettel more often than not (e.g. by winning at least 3 GPs). Of course, vice-versa holds true - if Bottas can raise his game in the races where Hamilton wins and secure a position higher than Vettel, it will be damaging to Vettels WDC ambition. Under this scenario, Hamilton could get away with 2 wins (if he continues to secure two 3rd and two 4th positions).
...so, having that said; Anyone feel free to start shredding my numbers to pieces.
Of course, nice treatment, critical thoughts or suggestions are always preferable.
