Re: Renault V6 Power Unit
The compression ratios as far as people on this website estimate.. are in the range of maybe 16:1 and higher.... Maybe guru or Wazari can give more insight. The engines are still spark ignition obviously, but they achieve a sort of quasi-homogeneous combustion using jet-fired ignition.
The MGUH doesn't affect the combustion itself, but it is the most expensive, cutting edge, most computationally demanding, fragile, assembly on the car that adds to the whole "green" initiative but nearly zero to road relevance and race spectacle.
Postmoe
PlatinumZealot wrote: ↑
14 Nov 2017, 00:23
I'm very interested by this statement. Why can't MGUH have road car applications?
hemichromis
hemichromis
Postmoe wrote: ↑
14 Nov 2017, 13:18
14 Nov 2017, 00:23
I'm also wondering this. Couldn't the cost come down in time or is it another problem?
noname
noname
14 Nov 2017, 00:23
(...) The MGUH doesn't affect the combustion itself, but it is the most expensive, cutting edge, most computationally demanding, fragile, assembly on the car that adds to the whole "green" initiative but nearly zero to road relevance and race spectacle.
It is an amazing piece of engineering, indeed, but it is neither extremely complex nor ultra-fragile. I can think of few other subsystems being higher in those categories, like turbocharger.
Neither it is non-relevant. There are few engines utilizing MGUH on the way, SOPs already defined.
MrPotatoHead
53
14 Nov 2017, 00:23
Silliest thing I've read here in a long time. :P
The MGU-H is extremely exciting when it comes to the prospect of use in Road Cars and the aftermarket in race cars.
I've actually thought about starting a company in this area because it is so exciting.
You only have to look at Bosch who already offer electronic supplementary superchargers (fitted in Audi Turbo Diesels) to see that this technology will emerge before too long in the real world.
Plug in electric cars are not the future (not anytime soon anyway) - the future of more efficient road cars is the use of ERS systems (both kinetic and heat) to improve engine efficiency while still having a usable range.
I'm working with an OEM right now on this same subject and the predicted production numbers for Hybrid KERS based cars vs Plug In doesn't even compare.
FW17
189
MrPotatoHead wrote: ↑
14 Nov 2017, 15:19
14 Nov 2017, 00:23
And electric motors are cheap
It makes sense to have a electric turbine generator and electric super charger separately, will simplify the electronic controls to a certain extent.
MrPotatoHead
53
FW17 wrote: ↑
14 Nov 2017, 16:06
14 Nov 2017, 15:19
14 Nov 2017, 00:23
Exactly. Not only that but it makes packaging easier.
One of the problems though is the higher voltage circuits needed to reduce the current demand.
I think the OEM Bosch units I mentioned are running at 48V.
14 Nov 2017, 15:19
14 Nov 2017, 00:23
Have a look at some of the engineering challenges of building the MGUH. The electronics and materials are nuts! Road cars also don't operate in the constantly high loaded mode like a race car so there would be little waste heat to recover.
Listen out if you hear anything on MGUH implementation. For economical reasons... I would be surprized if it released on anything than limited run hyper-road cars with F1 engine.
dren
228
14 Nov 2017, 16:22
I'm' surprised cars haven't made the leap into higher voltages already.
Honda!
14 Nov 2017, 00:23
The MGUH doesn't affect combustion directly, but it does indirectly by controlling the turbo, which means you can control airflow into the engine, as well as pressure ratios,(which affects cylinder pressures) intake pressure and exhaust back pressure, all things that are integral to the combustion process.
63l8qrrfy6
63l8qrrfy6
368
Sieper wrote: ↑
13 Nov 2017, 17:11
but then again, plonk an engine "that dominated for a decade" in a current car (for arguments sake let's disregard it wouldn't meet current regulations) and see the car struggle. The current level of integrations of different specialties is just on such a different level. I do agree with your point that the creative power of a small team is lost, but how can you still meet the requirements of a designing a current gen engine with a small team, it is just undoable. If you could find a way, have such a great team then yes, you could still gain a great advantage by harnassing their skills.
In my own field of expertise (ERP Software) we are also way past this point, you can only know/understand a small fraction of the workings.
You can't really compare an engine that was designed so long ago to modern F1 engines.
As a matter of fact F1 is an exception to what I have said - the teams are comparatively small and work to relatively 'loose' standards. I know for a fact that Mercedes had about a dozen engineers that worked on the inline 4 turbo and had it running on the dyno in 4 months or so.
Mansell89
Mansell89
Guys just looking for some clarification re: the Renault PU for next year.
I have read two contrasting interviews from Cyril that have left me unsure.
Originally I read an article that said Renault would have a large upgrade for 2018 and that they would not be able to bring it forward to 2017. https://www.google.co.uk/amp/www.crash. ... 2018%3famp
However, there then seemed to be the idea that it was 2017 where they made a lot of change (hence reliability issues this year) and that basically we would see regular updates and performance-related gains. https://www.autosport.com/f1/news/13123 ... e-for-2017
Can anyone provide any clarity on whether there is a big change in architecture or design for 2018?
Does anyone hold hope that they can get close to the Merc/Ferrari level?
baybars
baybars
Mansell89 wrote: ↑
15 Nov 2017, 03:47
I suggest that you follow Taffin comment about PU.
Taffin said that 2017 and 2018 PU same architecture.
Renault has already tested some 2018 parts on 2017 PU
https://www.thecheckeredflag.co.uk/2017 ... rand-prix/
GhostF1
GhostF1
115
Mansell89 wrote: ↑
15 Nov 2017, 03:47
As far as I am aware, and from what I've read from Abiteboul throughout the season is Renault had a change in engine concept this year and will continue with this in 2018, at the start he said they would have 3 or 4 noticeable hardware upgrades throughout the season, however as the season progressed, he retracted that and said there would be no or minimal hardware changes this year and would only be providing engine management or minor upgrades. NOW though he is claiming Renault will make a noticeable step in 2018.
And while I have absolutely no doubt that the Renault will improve, the thing about Abiteboul is, he seems to make A LOT of promises, to later ignore what he's said previously or provide a completely different set of expectations. We've mentioned this plenty of times.
I'm expecting 2018 Winter testing to be this:
The 2018 Renault PU to be good from the outset, not top 2, but competitive, and Abiteboul will claim there is plenty to come as they concentrate on reliability over power for the short term and pace will be unlocked as the season progresses.
It's his go to line as he has said the same thing for 3 years.
MrPotatoHead
53
Hopefully Renault will not change too much for next year so that they can get to the bottom of their reliability and production problems.
I predict a podium finish for a Renault Powered McLaren at the first race of 2018 (Alonso of course)
