The app can be accessed from the championship website (www.mantiumchallenge.com/caeses/). It works entirely within your browser, so there is no need to download any fancy software....
Once loaded up you are presented with three pages which allow you to design three different parts of the car: the front wing, the rear wing, and the underfloor/diffuser. The main body of the car being provided by one of the championship sponsors (CAEDevice).
You adjust the design by modifying the sliders on the left of the screen...
This approach is far better than merely drawing these parts free-hand as it means you can easily make precise adjustments and also easily return to a previous specification by returning to the original settings.
The final round of the 2017 MVRC championship is rapidly approaching and I thought I would enter a car. With no data to start with I would be at a significant disadvantage compared to the existing entrants... so my only choice was to look at what the other competitors are doing...
I went to the Mantium Challenge webpage and looked at the published images and data from the last round for the Brook Motorsport car:-
Using the CAESES app I recreated as best I could a set-up that looked as close to the Brook Motorsport car as I could...
I then loaded up the VIRTUAL STOPWATCH lap timing software used by the MVRC Championship (Shameless plug; www.competition-car-engineering.com/MVRC_Timing.htm !!!), and put in the aero coefficients for the Brook Motorsport car and selected the Le Mans track. The data window at the bottom of the VIRTUAL STOPWATCH page showed me what I would need to do to make the car quicker around the Le Mans track...
...So I headed back to the CAESES app and set about making the adjustments which I thought would help me achieve what I needed: namely a more rearward downforce balance and a lower drag configuration.... Once created I just downloaded the parts and ZIPed them up ready for submission to the championship when the entry date arrives in a week or so's time so that the CFD analysis can be done by the championship organisers and then all cars will be run on VIRTUAL STOPWATCH to determine a winner...
When I receive the CFD results I will post a further update. I hope this little post might encourage others to try the CAESES app and join us on the [virtual] track next year!
