Indy car windscreen
jjn9128
769
Re: Indy car windscreen
Interesting interview with Laurent Mekies, of the FIA saftey group about the Indycar deflector/screen/shield.
However, Mekies admits the windscreen will "not necessarily" adhere to the same safety standards as the Halo as a different solution could also provide a different type of protection.
"One of the key aspects is to pick a load case – what are you trying to protect against? There is no absolute truth with that; nobody is wrong and nobody is right. You choose what you try to protect against, and after that you have to accept if something more than that happens it won't help, or not as much as is needed.
"We'll catch up to see where the items they tried puts them in terms of protection level. You might remember that we had ourselves scanned different protection levels. The shield itself we tried at Silverstone last year had a slightly reduced protection level, so it's a matter of finding a good compromise.
"It's very good that such an important player as IndyCar is getting very involved in this, and as I said we are working very closely with them."
Full article http://www.racer.com/indycar/item/14733 ... windscreen
#aerogandalf
Zynerji
110
I imagine a very simple titanium bezel around the top loop of the indy screen, and fastened at the back end of the screen would add an immense amount of strength to this design. Something like a 10mm piece of channel stock that fits snugly would redirect an enormous amount of impact energy around the driver.
I'm sure the right people are moving this forward as we type these speculations.
J.A.W.
109
Zynerji wrote:
13 Feb 2018, 03:13
Such a U-channel seating at the base of the screen would likely be a more useful addition, as the calculated
flex capability of the resilient 'plastic' may be compromised by such a metallic ad-hoc/add-on, up top, perhaps.
Zynerji
110
A frame for the window to be held within is an ad-hoc addition? 🤔🤔🤔
J.A.W.
109
Zynerji wrote:
13 Feb 2018, 14:23
One added to the top as an afterthought, & sans recalculation of dynamics, yeah, for sure..
Jolle
132
J.A.W. wrote:
13 Feb 2018, 15:01
Zynerji wrote:
13 Feb 2018, 14:23
And for added strength a bar between the top and the chassis... like... a halo, covered with a screen. And when rubber and dirt is a problem, take away the screen.
J.A.W.
109
Jolle wrote:
13 Feb 2018, 15:12
J.A.W. wrote:
13 Feb 2018, 15:01
Zynerji wrote:
13 Feb 2018, 14:23
Or clean the screen, but do not add any needless metal framing - that really does block the driver's view..
dren
226
I don't know why we don't go to completely enclosed cockpits. It'd be both safer and better looking. The aero guys would even like it.
Honda!
NathanOlder
You cant just close the cockpit and put a door on the side though, The survival cell would be weakened massively by doing this ? surely ?
GoLandoGo
Lewis v2.0
King George has arrived.
strad
117
Why not just have tear-offs?
Back to Adrian Newey's book: Their research showed the drivers only look straight ahead to the next corner and cross angle to the apex.
Is there something I'm missing with all this talk of cleaning? Seems straight forward and un complex.
Sir Stirling Moss
djos
113
Contact:
NathanOlder wrote:
15 Feb 2018, 15:21
Fighter jets don't have doors, the canopy just lifts up. The same would apply to F1 cars.
"In downforce we trust"
NathanOlder
djos wrote:
15 Feb 2018, 22:36
NathanOlder wrote:
15 Feb 2018, 15:21
and when the car is upside down the canopy just lif....... oh crap.
or if you just have a smash in the wall and damage the hinging mechanism , the thing wont even open.
GoLandoGo
Lewis v2.0
roon
412
NathanOlder wrote:
15 Feb 2018, 22:38
djos wrote:
15 Feb 2018, 22:36
NathanOlder wrote:
15 Feb 2018, 15:21
FIA procedure is to upright flipped cars before driver exit or extraction.
AJI
AJI
27
NathanOlder wrote:
15 Feb 2018, 22:38
djos wrote:
15 Feb 2018, 22:36
NathanOlder wrote:
15 Feb 2018, 15:21
Has anyone seen tests of drivers exciting an inverted Halo equipped car? I can't imagine it's easy?
jjn9128
769
AJI wrote:
15 Feb 2018, 22:43
#aerogandalf
