Aston Martin Red Bull Racing TAG Heuer RB14
F1NAC
164
Re: Aston Martin Red Bull Racing TAG Heuer RB14
Morteza wrote:
19 Feb 2018, 11:34
Check out at how unusual the RB14 upper wishbones on the front suspension are linked to the chassis! And how bent they are!
https://pbs.twimg.com/media/DWY2cJgX4AEtjmJ.jpg
https://pbs.twimg.com/media/DWY2c2-WkAAXhpN.jpg
fine angled towards inner side of bargeboards. you can see it. Perfect photo =D>
It looks also that they've integrated steering rod into lower A wishbone
santos
santos
WOW! The sidepods are soooo slim. Where did they put the radiators? :wtf:
Silent Storm
Silent Storm
106
The stat points between an Online Forum and Real Life are inversely proportional...
Flying JPS Lotus
37
Little Ducky wrote:
19 Feb 2018, 11:42
I see no S-duct... hmm interesting
It's still there in the same spot it was on the RB13. Check the #3 on the chassis and you'll find the s-duct.
"Looks like meat's back on the menu boys!"
#AeroUruk-Hai
adrianjordan
Now THAT's how you do Size Zero!!
Favourite team: McLaren
Jolle
Jolle
132
Looks like that the air that goes over the regulated section of the FW is channeled into the sidepods.
Funny to see by the way that they didn't use the Mercedes/Toro-Rosso raised suspension of last year. Like they all choose a different concept on which plane the air is the least disturbed.
seezung
seezung
56
The angle on the wishbones :o
Webber2011
Webber2011
So help me out to understand please guys.
I've always been here to learn.
Do those "wings" above the sidepods create mid chassis downforce, or are they more about something else ?
designf1
designf1
73
Webber2011 wrote:
19 Feb 2018, 12:05
The ones at the top of the sidepods angle downwards which should create lift. They are being used to direct flow around the sloping shoulder of the sidepods. The slight lift they produce will be more than offset by increases in downforce elsewhere or by a net reduction in overall lift.
They have a tip washout/flick that is trying to reduce vortex generation, interestingly, just as on an aircraft wing.
noxroxafox
noxroxafox
I'm glad that they've made it more agressive compared to the launch-spec of the RB13, atleast, for the eye.
iichel
iichel
noxroxafox wrote:
19 Feb 2018, 12:11
There were some issues with the correlation between track/wind tunnel with the early RB13, so they kept it very simple. Additionally, since the RB14 is an evolution of the RB13, it makes sense that it's more aggressively shaped with more winglets etc.
Webber2011
Webber2011
Just_a_fan wrote:
19 Feb 2018, 12:10
Webber2011 wrote:
19 Feb 2018, 12:05
Yeah cool, thanks for your thoughts mate :wink:
So they're all about getting cleaner air to go around and under the side pod right ?
Is there any benefit you can see as to the way air goes into the side pod ?
DinkLv
DinkLv
62
So similar
Silent Storm
Silent Storm
106
